Nikon Coolpix S6300 Zoom Lens Gears
  1. Nikon Coolpix S6300 Zoom Lens Gears, Battery: step 1, image 1 of 1
    • Place the camera facing upwards.
    • Press down on the battery cover and slide towards the front face of the camera.
  2. Nikon Coolpix S6300 Zoom Lens Gears: step 2, image 1 of 1
    • Rotate the orange battery clip in the camera to release the battery.
    long press it
    Tech Vishwak - Reply
    then it works
  3. Nikon Coolpix S6300 Zoom Lens Gears, Buttons: step 3, image 1 of 3 Nikon Coolpix S6300 Zoom Lens Gears, Buttons: step 3, image 2 of 3 Nikon Coolpix S6300 Zoom Lens Gears, Buttons: step 3, image 3 of 3
    • Locate the eight outer PH 2mm screws on the device.
    • Using the PH00 screwdriver remove all of the screws from the camera.
  4. Nikon Coolpix S6300 Zoom Lens Gears: step 4, image 1 of 3 Nikon Coolpix S6300 Zoom Lens Gears: step 4, image 2 of 3 Nikon Coolpix S6300 Zoom Lens Gears: step 4, image 3 of 3
    • Using a plastic opening tool, gently pry off the front and rear plates.
    • Be patient with this step, do not force the clips holding the plates together.
  5. Nikon Coolpix S6300 Zoom Lens Gears: step 5, image 1 of 1
    • Using a Phillips #00 screwdriver, remove the PH 2 mm screw located to the right of the screen, above the OK dial.
  6. Nikon Coolpix S6300 Zoom Lens Gears: step 6, image 1 of 1
    • Disconnect the connectors using a plastic spudger.
    • Be careful when removing the cables to prevent damaging the connectors.
  7. Nikon Coolpix S6300 Zoom Lens Gears: step 7, image 1 of 1
    • You may now remove the internal panel of the buttons.
  8. Nikon Coolpix S6300 Zoom Lens Gears, Display: step 8, image 1 of 1
    • Remove the clasp from the ribbon cable using the plastic spudger.
    • Make sure to be gentle when removing the clasp to prevent it from ripping.
    • You may now remove the display.
  9. Nikon Coolpix S6300 Zoom Lens Gears, Polarizing Lens: step 9, image 1 of 3 Nikon Coolpix S6300 Zoom Lens Gears, Polarizing Lens: step 9, image 2 of 3 Nikon Coolpix S6300 Zoom Lens Gears, Polarizing Lens: step 9, image 3 of 3
    • Remove the four PH00 2.5 mm screws around the edges of the display plate.
    • Remove the three PH00 2 mm screws from the sides of the buttons plate and the 2.5 mm screw from the center of the buttons plate.
    • Lift the buttons plate out of the camera with the plastic tool.
    • Lift the display plate out of the camera with the plastic tool.
  10. Nikon Coolpix S6300 Zoom Lens Gears: step 10, image 1 of 3 Nikon Coolpix S6300 Zoom Lens Gears: step 10, image 2 of 3 Nikon Coolpix S6300 Zoom Lens Gears: step 10, image 3 of 3
    Tool used on this step:
    Buy
    • Use the plastic opening tool to gently flip the white folders at the end of the ribbon cables.
    • Use this tweezers to gently pull the cables out of the holders.
    • Lift the lens apparatus out of the rest of the camera by pushing the front of lens up from the bottom.
  11. Nikon Coolpix S6300 Zoom Lens Gears: step 11, image 1 of 2 Nikon Coolpix S6300 Zoom Lens Gears: step 11, image 2 of 2
    • Use the plastic opening tool to flip the two white clips holding the ribbon cables.
    • Use tweezers to pull the cables from clamps.
    • Use the PH00 screwdriver to remove the three 2 mm screws around the first lens area.
  12. Nikon Coolpix S6300 Zoom Lens Gears: step 12, image 1 of 2 Nikon Coolpix S6300 Zoom Lens Gears: step 12, image 2 of 2
    • Lift the first lens from the rest of the lens apparatus.
    • Use thin tweezers to left and remove the polarizing lens from the apparatus.
  13. Nikon Coolpix S6300 Zoom Lens Gears, Zoom Lens Gears: step 13, image 1 of 1
    Buy
    • Check to see if there are any items stuck inside the gear.
    • Carefully remove items using tweezers.
    • If the gears are popped out of place, carefully push the gears back into its original position shown in the picture
4 other people completed this guide.
Hung
383 Reputation
2 Guides authored
USF Tampa, Team 1-2, Remmell Fall 2015 Member of USF Tampa, Team 1-2, Remmell Fall 2015
USFT-REMMELL-F15S1G2
5 Members
10 Guides authored
One Comment
Attention rester sur une table, et bien suivre le tutoriel. En effet, il y a des pilles, Pas la batterie: donc si vous touchez le haut de l'appareil, il y a un peux d’électricité max 4w , ce qui surprend....C'est pas dangereux mais cela surprend. Pas toucher le haut de l'appareil..... Ferreria J-C
a420mf - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 16
All Time: 1,529
