Nikon Coolpix S70 Display Screen Replacement
  1. Nikon Coolpix S70 Display Screen Replacement, Display Screen: step 1, image 1 of 2 Nikon Coolpix S70 Display Screen Replacement, Display Screen: step 1, image 2 of 2
    • Power off the camera before beginning.
    • Remove the battery by sliding the latch located at the bottom of the camera.
  2. Nikon Coolpix S70 Display Screen Replacement: step 2, image 1 of 2 Nikon Coolpix S70 Display Screen Replacement: step 2, image 2 of 2
    • Using a Phillips head #000 screwdriver, remove the five 0.4mm screws on the bottom of the camera.
  3. Nikon Coolpix S70 Display Screen Replacement: step 3, image 1 of 3 Nikon Coolpix S70 Display Screen Replacement: step 3, image 2 of 3 Nikon Coolpix S70 Display Screen Replacement: step 3, image 3 of 3
    • Use a plastic opening tool to carefully separate the back panel of the camera.
    • Once loosened, use your fingers to manually separate the two panels.
  4. Nikon Coolpix S70 Display Screen Replacement: step 4, image 1 of 3 Nikon Coolpix S70 Display Screen Replacement: step 4, image 2 of 3 Nikon Coolpix S70 Display Screen Replacement: step 4, image 3 of 3
    • Using a plastic opening tool, lift both latches that hold the ribbon cables in place.
  5. Nikon Coolpix S70 Display Screen Replacement: step 5, image 1 of 1
    • Carefully disconnect the orange flat ribbon cables from the latches.
  6. Nikon Coolpix S70 Display Screen Replacement: step 6, image 1 of 3 Nikon Coolpix S70 Display Screen Replacement: step 6, image 2 of 3 Nikon Coolpix S70 Display Screen Replacement: step 6, image 3 of 3
    • Remove the screen from the case of the camera by carefully pushing on the back of the screen.
    • You may need to push with a little force to get the screen to loosen.
4 other people completed this guide.
Danielle Morris
177 Reputation
1 Guide authored
Texas Tech, Team 22-2, Rauch Fall 2015 Member of Texas Tech, Team 22-2, Rauch Fall 2015
TTU-RAUCH-F15S22G2
3 Members
1 Guide authored
One Comment
my camera's lens show blury photos and when zooming id makes sound
Aliudin Saleh - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 1,149
