Nikon Coolpix S7000 Shutter Button Replacement
  1. Nikon Coolpix S7000 Shutter Button Replacement, Shutter Button: step 1, image 1 of 2 Nikon Coolpix S7000 Shutter Button Replacement, Shutter Button: step 1, image 2 of 2
    • Remove the outer frame of the camera by unscrewing the screws around its sides with a JIS J000 screwdriver.
    • Screw locations.
  2. Nikon Coolpix S7000 Shutter Button Replacement: step 2, image 1 of 2 Nikon Coolpix S7000 Shutter Button Replacement: step 2, image 2 of 2
    • Remove outer camera frames by carefully pulling the frame apart from the body of the camera.
  3. Nikon Coolpix S7000 Shutter Button Replacement: step 3, image 1 of 2 Nikon Coolpix S7000 Shutter Button Replacement: step 3, image 2 of 2
    • Once the shutter button assembly is removed from the camera shell, carefully remove the black tape on the underside of the metal plate.
    • Black tape.
    • Do not discard the tape as you will reapply it when putting the shutter assembly back together.
  4. Nikon Coolpix S7000 Shutter Button Replacement: step 4, image 1 of 3 Nikon Coolpix S7000 Shutter Button Replacement: step 4, image 2 of 3 Nikon Coolpix S7000 Shutter Button Replacement: step 4, image 3 of 3
    • Unscrew the two screws on each side of the metal plate to remove the plate and springs underneath it.
    • Push the button through the assembly to release it and then carefully remove the button cover to reveal the coiled spring and bottom cover.
    • Locations of the two screws.
    • Be very careful not to lose the two metal plate springs and the coiled spring when disassembling. A slow and steady hand will help prevent the springs from ejecting.
Nicholas Leon-Schetina
113 Reputation
1 Guide authored
USF Tampa, Team S2-G3, Lacy Spring 2017 Member of USF Tampa, Team S2-G3, Lacy Spring 2017
USFT-LACY-S17S2G3
4 Members
10 Guides authored
One Comment
shutter keeps trying to open. clicks slighly and does not open
Beatrix - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 13
All Time: 778
