Nikon Coolpix S7000 Sticky Button Replacement
    • Clean your camera buttons. This can be done using isopropyl alcohol and a cotton swab. If the button is still jammed, proceed to Step 2.
  1. Nikon Coolpix S7000 Sticky Button Replacement: step 2, image 1 of 3 Nikon Coolpix S7000 Sticky Button Replacement: step 2, image 2 of 3 Nikon Coolpix S7000 Sticky Button Replacement: step 2, image 3 of 3
    • Remove the outer frame of the camera by unscrewing the screws around its sides with a JIS J000 screwdriver.
    • 3.2mm screws (not fully threaded)
    • 3mm screws
    • 4.2mm screws (coarser thread)
  2. Nikon Coolpix S7000 Sticky Button Replacement: step 3, image 1 of 2 Nikon Coolpix S7000 Sticky Button Replacement: step 3, image 2 of 2
    • Remove outer camera frames by carefully pulling the frame apart from the body of the camera.
  3. Nikon Coolpix S7000 Sticky Button Replacement: step 4, image 1 of 3 Nikon Coolpix S7000 Sticky Button Replacement: step 4, image 2 of 3 Nikon Coolpix S7000 Sticky Button Replacement: step 4, image 3 of 3
    • At this point push out any buttons that were jammed, and, clean the inside portion where the button sits inside the frames with isopropyl alcohol and a cotton swab as moisture may have found its way inside the camera causing stickiness.
    • Swab this portion.
  4. Nikon Coolpix S7000 Sticky Button Replacement: step 5, image 1 of 1
    • If the navigation button is stuck, twist it around while the frame is removed to see if you can locate any obstructions.
    • If the shutter button is stuck, press up against it from the inside with your finger or the screwdriver to dislodge it.
  5. Nikon Coolpix S7000 Sticky Button Replacement: step 6, image 1 of 1
Shannon Beane
324 Reputation
2 Guides authored
USF Tampa, Team S2-G3, Lacy Spring 2017 Member of USF Tampa, Team S2-G3, Lacy Spring 2017
USFT-LACY-S17S2G3
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 31
All Time: 2,332
