Nikon Coolpix S9050 LCD Screen Replacement
  1. Nikon Coolpix S9050 LCD Screen Replacement, Menu Wheel and OK Button: step 1, image 1 of 3 Nikon Coolpix S9050 LCD Screen Replacement, Menu Wheel and OK Button: step 1, image 2 of 3 Nikon Coolpix S9050 LCD Screen Replacement, Menu Wheel and OK Button: step 1, image 3 of 3
    • Using a Phillips #000 screwdriver, remove the two 3.2mm black screws on both sides of the camera.
    • Set the camera face down and remove the four 3.2mm silver screws using the same screwdriver.
  2. Nikon Coolpix S9050 LCD Screen Replacement: step 2, image 1 of 1
    • Remove the display frame and trim from the main body of the camera.
  3. Nikon Coolpix S9050 LCD Screen Replacement: step 3, image 1 of 3 Nikon Coolpix S9050 LCD Screen Replacement: step 3, image 2 of 3 Nikon Coolpix S9050 LCD Screen Replacement: step 3, image 3 of 3
    • Press down and pull the Menu Wheel/OK Button panel toward the screen.
    • This releases the panel from the slots.
  4. Nikon Coolpix S9050 LCD Screen Replacement: step 4, image 1 of 3 Nikon Coolpix S9050 LCD Screen Replacement: step 4, image 2 of 3 Nikon Coolpix S9050 LCD Screen Replacement: step 4, image 3 of 3
    • Lift the black plastic tabs, which are securing the panel.
    • Gently pull the panel out to separate the display ribbon cable from the camera body.
  5. Nikon Coolpix S9050 LCD Screen Replacement, LCD Screen: step 5, image 1 of 1
    • Remove the silver 3.2 mm Phillips #000 screw on the corner of the device to remove the screen.
  6. Nikon Coolpix S9050 LCD Screen Replacement: step 6, image 1 of 2 Nikon Coolpix S9050 LCD Screen Replacement: step 6, image 2 of 2
    • Gently remove pin connector using the spudger to disconnect the screen.
Kyle Gildner
199 Reputation
2 Guides authored
IUPUI, Team S1-G5, Stella Fall 2019 Member of IUPUI, Team S1-G5, Stella Fall 2019
IUPUI-STELLA-F19S1G5
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 267
