Nikon Coolpix S9700 Battery Replacement
Matt Staubus
Matt Staubus and one other contributor
Last updated on August 15, 2020
2 minutes
Easy
Introduction
Go to step 1
You may need a new battery if you have noticed your S9700 needs charging more often, if your S9700 keeps turning off for no apparent reason, or a variety of other issues. Removing the battery is very simple and does not require a lot of knowledge of the camera itself. With a new battery installed, you can be a photographer with confidence.
  1. Nikon Coolpix S9700 Battery Replacement, Battery: step 1, image 1 of 2 Nikon Coolpix S9700 Battery Replacement, Battery: step 1, image 2 of 2
    • Press the ON/OFF button to power off the S9700.
    • Not doing so can damage the S9700 or cause electric shock.
  2. Nikon Coolpix S9700 Battery Replacement: step 2, image 1 of 3 Nikon Coolpix S9700 Battery Replacement: step 2, image 2 of 3 Nikon Coolpix S9700 Battery Replacement: step 2, image 3 of 3
    • Place the S9700 upside down
    • Place your finger on the battery compartment cover and gently push toward the front of the S9700.
    • The cover will open up by itself.
  3. Nikon Coolpix S9700 Battery Replacement: step 3, image 1 of 3 Nikon Coolpix S9700 Battery Replacement: step 3, image 2 of 3 Nikon Coolpix S9700 Battery Replacement: step 3, image 3 of 3
    • Push the yellow tab inside the battery compartment in the direction of the arrow. This will allow the battery to spring up.
  4. Nikon Coolpix S9700 Battery Replacement: step 4, image 1 of 2 Nikon Coolpix S9700 Battery Replacement: step 4, image 2 of 2
    • Grab the battery and pull out.
Matt Staubus
849 Reputation
5 Guides authored
USF Tampa, Team 9-5, Lacy Fall 2016 Member of USF Tampa, Team 9-5, Lacy Fall 2016
USFT-LACY-F16S9G5
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 25
All Time: 1,150
