Nikon D3100 LCD Screen Replacement
  1. Nikon D3100 LCD Screen Replacement, LCD Screen: step 1, image 1 of 1
    • Use a Phillips #00 screwdriver for all of the screws.
    • Remove two of the 4mm screws indicated by the circles on the bottom side of the camera.
  2. Nikon D3100 LCD Screen Replacement: step 2, image 1 of 2 Nikon D3100 LCD Screen Replacement: step 2, image 2 of 2
    • Remove four of the 3mm screws around the eye piece located on the top of the back panel, including the screw hidden behind the auto focus label.
    • Remove the 3mm screw behind the rubber grip on the top right of the back panel.
  3. Nikon D3100 LCD Screen Replacement: step 3, image 1 of 1
    • Peel back the rubber grip on the right side of the camera using a spudger.
    • You may need a heating pad to melt the glue holding the rubber grip to the camera. If using the heating pad, use caution and handle carefully.
    • Remove two of the 5mm screws under the rubber grip.
  4. Nikon D3100 LCD Screen Replacement: step 4, image 1 of 1
    • Remove two of the 4mm screws on the left side of the camera.
  5. Nikon D3100 LCD Screen Replacement: step 5, image 1 of 2 Nikon D3100 LCD Screen Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Starting from the top, gently lift the back panel of the camera off. Slowly separate the back panel from the main body of the camera.
    • Be careful not to pull the panel out too fast or the ribbon may be damaged.
    • Carefully remove the ribbon using a spudger to lift up the connector and then use tweezers to pull out the ribbon.
    • Separate the back panel from the main body of the camera.
  6. Nikon D3100 LCD Screen Replacement: step 6, image 1 of 1
    • Be careful when separating the metal plate from the back panel because the speaker wire is connected to the metal plate. It can easily be torn if caution is not taken.
    • Remove nine of the 3mm screws connecting the metal plate to the plastic panel.
  7. Nikon D3100 LCD Screen Replacement: step 7, image 1 of 1
    • Remove the tape covering the ribbons. Be careful not to break the tape.
  8. Nikon D3100 LCD Screen Replacement: step 8, image 1 of 1
    • Remove the two ribbons connecting the LCD screen to the metal plate using the same method from Step 5.
  9. Nikon D3100 LCD Screen Replacement: step 9, image 1 of 1
    • Remove the old LCD screen from metal plate.
8 other people completed this guide.
Jet Mejia
662 Reputation
3 Guides authored
USF Tampa, Team 14-1, Eyestone Fall 2016 Member of USF Tampa, Team 14-1, Eyestone Fall 2016
USFT-EYESTONE-F16S14G1
3 Members
4 Guides authored
5 Guide Comments
Very helpful guide, so happy to have a non-cracked screen again!
Rob Cuthbertson - Reply
now, where can i buy this replacement screen here in the Philippines?
leumas_erbutco - Reply
does anyone have the part number for the replacement screen?
Lee Caterson - Reply
Très bien ce document, seulement l'écran LCD pour Nikon D3100 semble introuvable, et épuisé !!! Avez-vous une adresse valable pour commander?
gtre - Reply
Hello, regarde ici ça devrait correspondre:
https://fra.grandado.com/products/origin...
Lou Lou - Reply
Past 24 Hours: 3
Past 7 Days: 44
Past 30 Days: 156
All Time: 15,274
