Introduction
If your camera is malfunctioning or the external connection (micro USB and HDMI) ports are not working, then the camera's motherboard might be faulty and needs to be replaced. Before starting with this guide, refer to this troubleshooting page to check if there are any other possible causes.
Remove two of the 4mm screws indicated by the circles on the bottom side of the camera.
Starting from the top, gently lift the back panel of the camera off. Slowly separate the back panel from the main body of the camera.
Carefully remove the ribbon using a spudger to lift up the connector and then use tweezers to pull out the ribbon.
Separate the back panel from the main body of the camera.
Use tweezers to gently lift the yellow tape from the back of the camera.
4 other people completed this guide.
