Nikon D40 Flash Pin Replacement
  1. Nikon D40 Flash Pin Replacement, Flash Pin: step 1, image 1 of 1
    • Turn off the camera and remove the battery.
  2. Nikon D40 Flash Pin Replacement: step 2, image 1 of 1
    • Pry the flash open using the plastic opening tool.
  3. Nikon D40 Flash Pin Replacement: step 3, image 1 of 1
    • Remove the two Phillips #0 3.0 mm screws from the front of the flash compartment using the small Phillips Head screwdriver.
  4. Nikon D40 Flash Pin Replacement: step 4, image 1 of 2 Nikon D40 Flash Pin Replacement: step 4, image 2 of 2
    • Pry off the back plastic of the flash compartment using the plastic opening tool.
    • When it is time to reassemble the flash module, a certain amount of force and precise alignment will be required.
  5. Nikon D40 Flash Pin Replacement: step 5, image 1 of 2 Nikon D40 Flash Pin Replacement: step 5, image 2 of 2
    • On the left of the camera you will see a metal spring.
    • Unscrew the Phillips #0 3.0 mm screw holding the spring in place, using the small Phillips Head screwdriver.
  6. Nikon D40 Flash Pin Replacement: step 6, image 1 of 1
    • Remove metal spring and replace with new spring.
4 other people completed this guide.
Lindsey Chase
227 Reputation
1 Guide authored
Cal Poly, Team 6-19, Maness Winter 2014 Member of Cal Poly, Team 6-19, Maness Winter 2014
CPSU-MANESS-W14S6G19
4 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 153
All Time: 4,289
