Nikon D40 Mainboard Replacement
  1. Nikon D40 Mainboard Replacement, Back Cover: step 1, image 1 of 1
    • Remove the two visible 6.0 mm Philips #0 screws on the left and right sides of the viewfinder. These screws are highlighted in red.
  2. Nikon D40 Mainboard Replacement: step 2, image 1 of 2 Nikon D40 Mainboard Replacement: step 2, image 2 of 2
    • Remove the four 6.0 mm Philips #0 screws on the left and right sides of the camera.
  3. Nikon D40 Mainboard Replacement: step 3, image 1 of 1
    • Remove the four highlighted 3.0 mm Philips #0 screws on the bottom of the camera.
  4. Nikon D40 Mainboard Replacement: step 4, image 1 of 1
    • While pulling the bottom down, remove the back of the camera.
    • Be careful not to pull too hard on the back as it is connected via a ribbon cable. Be sure to disconnect this cable on the main board.
    • To disconnect the ribbon cable pull the small black tab upward and pull gently on the cable.
  5. Nikon D40 Mainboard Replacement, Mainboard: step 5, image 1 of 2 Nikon D40 Mainboard Replacement, Mainboard: step 5, image 2 of 2
    • Remove the solder connecting the red wire to the mainboard.
  6. Nikon D40 Mainboard Replacement: step 6, image 1 of 1
    • Desolder the 4 smaller wires near the bottom of the mainboard.
  7. Nikon D40 Mainboard Replacement: step 7, image 1 of 2 Nikon D40 Mainboard Replacement: step 7, image 2 of 2
    • Use the plastic opening tool to release the ribbon cables attached to the mainboard.
  8. Nikon D40 Mainboard Replacement: step 8, image 1 of 1
    • Remove the five 3.0mm Philips #1 screws holding the mainboard down.
  9. Nikon D40 Mainboard Replacement: step 9, image 1 of 2 Nikon D40 Mainboard Replacement: step 9, image 2 of 2
    • Lift the mainboard up to reveal the final connection.
    • Carefully detach the white cable from the board.
7 other people completed this guide.
Joe Leija
632 Reputation
2 Guides authored
Cal Poly, Team 6-19, Maness Winter 2014 Member of Cal Poly, Team 6-19, Maness Winter 2014
CPSU-MANESS-W14S6G19
4 Members
7 Guides authored
3 Guide Comments
What is the ordering of the small wires on the bottom? It is hard to put back together from the photos. Thanks!
Joseph Ruskiewicz - Reply
wheres the power source? i mean the fuse
Gringo Maputi - Reply
in the main board located kindly put markings on it
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 27
All Time: 4,760
