Nikon D40 Viewfinder Replacement
  1. Nikon D40 Viewfinder Replacement, Back Cover: step 1, image 1 of 1
    • Remove the two visible 6.0 mm Philips #0 screws on the left and right sides of the viewfinder. These screws are highlighted in red.
  2. Nikon D40 Viewfinder Replacement: step 2, image 1 of 2 Nikon D40 Viewfinder Replacement: step 2, image 2 of 2
    • Remove the four 6.0 mm Philips #0 screws on the left and right sides of the camera.
  3. Nikon D40 Viewfinder Replacement: step 3, image 1 of 1
    • Remove the four highlighted 3.0 mm Philips #0 screws on the bottom of the camera.
  4. Nikon D40 Viewfinder Replacement: step 4, image 1 of 1
    • While pulling the bottom down, remove the back of the camera.
    • Be careful not to pull too hard on the back as it is connected via a ribbon cable. Be sure to disconnect this cable on the main board.
    • To disconnect the ribbon cable pull the small black tab upward and pull gently on the cable.
  5. Nikon D40 Viewfinder Replacement, Viewfinder: step 5, image 1 of 1
    • You will be able to see the ribbon cables coming out from the back panel, disconnect the cables.
    • Be careful not to pull too hard on the ribbon cables.
  6. Nikon D40 Viewfinder Replacement: step 6, image 1 of 1
    • Slowly push the upper body up until you see the frame of the viewfinder
    • Be careful while pulling the top camera body.
  7. Nikon D40 Viewfinder Replacement: step 7, image 1 of 1
    • Use a spudger to keep the upper body separate from the printed circuit board.
    • Wiggle the plastic eyepiece out of the frame. This may require some force.
  8. Nikon D40 Viewfinder Replacement: step 8, image 1 of 1
    • Remove the viewfinder with the plastic opening tool.
    • Do not push too hard while using the opening tool.
  9. Nikon D40 Viewfinder Replacement: step 9, image 1 of 1
    • The viewfinder has been removed!
2 other people completed this guide.
Amy Chen
193 Reputation
1 Guide authored
Cal Poly, Team 6-19, Maness Winter 2014 Member of Cal Poly, Team 6-19, Maness Winter 2014
CPSU-MANESS-W14S6G19
4 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 22
All Time: 3,676
