Nikon D5200 Screen Replacement
  1. Nikon D5200 Screen Replacement, Screen: step 1, image 1 of 3 Nikon D5200 Screen Replacement, Screen: step 1, image 2 of 3 Nikon D5200 Screen Replacement, Screen: step 1, image 3 of 3
    • Fully open the LCD panel so that its screws are easily accessible.
    • Remove the two 2.5 mm screws from the outside edge of the screen casing, and the two 3.5 mm screws from the inside edge.
  2. Nikon D5200 Screen Replacement: step 2, image 1 of 3 Nikon D5200 Screen Replacement: step 2, image 2 of 3 Nikon D5200 Screen Replacement: step 2, image 3 of 3
    • Pry open the plastic casing using the opening tool or by hand.
  3. Nikon D5200 Screen Replacement: step 3, image 1 of 3 Nikon D5200 Screen Replacement: step 3, image 2 of 3 Nikon D5200 Screen Replacement: step 3, image 3 of 3
    • Use the plastic opening tool to pop up the latch holding the ribbon cable on the right side of the circuit board, and remove it.
    • Use the plastic opening tool to pry the ribbon cable on the left side of the circuit board up and off of its socket.
  4. Nikon D5200 Screen Replacement: step 4, image 1 of 2 Nikon D5200 Screen Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers, unplug the smaller cable.
  5. Nikon D5200 Screen Replacement: step 5, image 1 of 2 Nikon D5200 Screen Replacement: step 5, image 2 of 2
    • Desolder the three small wires on the left side of the circuit board.
    • Soldering irons become very hot when in use. Take all necessary precautions to avoid injury.
  6. Nikon D5200 Screen Replacement: step 6, image 1 of 3 Nikon D5200 Screen Replacement: step 6, image 2 of 3 Nikon D5200 Screen Replacement: step 6, image 3 of 3
    • Using a spudger, remove the display from its casing.
15 other people completed this guide.
Alexander Corn
1,282 Reputation
5 Guides authored
USF Tampa, Team 3-1, Eyestone Fall 2015 Member of USF Tampa, Team 3-1, Eyestone Fall 2015
USFT-EYESTONE-F15S3G1
4 Members
5 Guides authored
8 Comments
Do I need to de-solder if I'm just replacing the window glass?
isaac - Reply
To isaac: no. The exterior glass is separate from the LCD.
Joseph Morris - Reply
Do you recommend the replacent for LCD sold on Ebay?
g_atki - Reply
Where did you find the replacement screen? The one I ordered that says it's for the d5200 is not the same as the one in it or in your pictures.
Heather Miller - Reply
How do you disconnect the multi-plug that is shown connected in image 4 and disconnected in image five? Does it unclip or slide out?
Amanda Bruyninckx - Reply
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 69
All Time: 11,950
