Nikon D610 Autofocus Drive Motor Replacement
  1. Nikon D610 Autofocus Drive Motor Replacement, Battery: step 1, image 1 of 1
    • First, power off the device.
  2. Nikon D610 Autofocus Drive Motor Replacement: step 2, image 1 of 3 Nikon D610 Autofocus Drive Motor Replacement: step 2, image 2 of 3 Nikon D610 Autofocus Drive Motor Replacement: step 2, image 3 of 3
    • Set the camera so that it is sitting on its side.
    • Open the battery compartment door by sliding the release button towards the lens.
    • This will cause the door to "pop" open slightly
  3. Nikon D610 Autofocus Drive Motor Replacement: step 3, image 1 of 2 Nikon D610 Autofocus Drive Motor Replacement: step 3, image 2 of 2
    • Now lift open the battery compartment door.
    • Push the yellow tab lock towards the center to release the battery.
    • This will cause the battery to jump up as there is a spring at the bottom.
    • Pull straight out, slowly on the battery.
    • Make sure you pay attention to which way the battery goes .
  4. Nikon D610 Autofocus Drive Motor Replacement, Outer Case: step 4, image 1 of 1
    • After removal of the battery. Pull the battery compartment door away from the lens.
    • There are eleven Philips head screws that hold the bottom cover on, including a few inside the battery compartment.
    • Remove all the screws and the bottom face should pop off easily.
  5. Nikon D610 Autofocus Drive Motor Replacement: step 5, image 1 of 3 Nikon D610 Autofocus Drive Motor Replacement: step 5, image 2 of 3 Nikon D610 Autofocus Drive Motor Replacement: step 5, image 3 of 3
    • Then next step is removing the seven Philips #00 screws that hold the rear face plate on.
    • There are screws hidden in three separate spots.
    • One is under the rubber doors on the left side of the camera. the next one at the eye hole.
    • The final one involves taking off the small dial that is about half an inch to the right of the eye hole.
    • Removing this dial involves putting a spungder tool behind it and applying a gradual amount of pressure.
  6. Nikon D610 Autofocus Drive Motor Replacement: step 6, image 1 of 2 Nikon D610 Autofocus Drive Motor Replacement: step 6, image 2 of 2
    • The rear face plate will include the LCD display it separates from the body of the camera with a small tug.
    • Do not pull to hard otherwise you risk breaking the ribbon wire that connects the controls and the screen.
    • Once there is enough space it will be possible to gently pull the ribbon cable out of their ports.
  7. Nikon D610 Autofocus Drive Motor Replacement: step 7, image 1 of 2 Nikon D610 Autofocus Drive Motor Replacement: step 7, image 2 of 2
    • The next piece to come off is the front plate and the red grip.
    • The front plate is held on by 2 Philips #00 screws on the front and two more beneath the flash bulb.
    • Remove the two Phillips #00 screws holding on the grip and it slides off easily.
    • After removing the screws the face plate comes off by pulling it straight off to avoid damage.
  8. Nikon D610 Autofocus Drive Motor Replacement: step 8, image 1 of 2 Nikon D610 Autofocus Drive Motor Replacement: step 8, image 2 of 2
    • It is now possible to remove the last three Philips #00 screws that are hidden under the memory card slot door.
    • The screws come out and the cover comes straight off.
    • The last cover plate is the top. The top is held on by two screws located just beneath the rim of the cover.
    • The top should be pulled off very slowly. There are several electronic components that connect between the body and the top.
    • There are three wires that need to be disconnected.
  9. Nikon D610 Autofocus Drive Motor Replacement, Motherboard: step 9, image 1 of 2 Nikon D610 Autofocus Drive Motor Replacement, Motherboard: step 9, image 2 of 2
    • The rear side of the camera is where the motherboard is located. It is visible after you have taken off the rear face plate.
    • Remove the shield that protects it from static first.
    • This shield has six Philips #00 screws that are positioned around the edge of the shield.
    • After removal of the screws the shield will come free from the motherboard.
  10. Nikon D610 Autofocus Drive Motor Replacement: step 10, image 1 of 2 Nikon D610 Autofocus Drive Motor Replacement: step 10, image 2 of 2
    • The six screws that were removed in the previous step also hold the motherboard in place.
    • There are a few ribbon cables that connect to the motherboard to the rest of the camera with some of them hiding under other ribbon cables.
    • Be very careful when removing the ribbon wires. If they break it can cause problems with needing more repairs.
  11. Nikon D610 Autofocus Drive Motor Replacement, Autofocus Drive Motor: step 11, image 1 of 3 Nikon D610 Autofocus Drive Motor Replacement, Autofocus Drive Motor: step 11, image 2 of 3 Nikon D610 Autofocus Drive Motor Replacement, Autofocus Drive Motor: step 11, image 3 of 3
    • The focus motor is located in between the right hand grip and the lens socket and requires several parts to be replaced as a whole because it is unreachable.
    • Begin by removing the silver ring around the lens socket by unscrewing the five screws supporting it.
  12. Nikon D610 Autofocus Drive Motor Replacement: step 12, image 1 of 1
    • Several screw and ribbon cables and the bottom portion of the camera need to be removed as shown in the picture
  13. Nikon D610 Autofocus Drive Motor Replacement: step 13, image 1 of 3 Nikon D610 Autofocus Drive Motor Replacement: step 13, image 2 of 3 Nikon D610 Autofocus Drive Motor Replacement: step 13, image 3 of 3
    • Now that the bottom is prepped we move onto the top.
    • Here we have more ribbon cables and screws that need to be removed that will end up releasing the top viewing lens area.
    • Some of the ribbon cables reach back around to the motherboard and may need to be removed there.
    • Also, there is a wire that runs along the top that just needs to be shifted out of the way.
    • be careful not to break the red or black wire attached to some of the ribbon cables as they will need to be re-soldered if broken.
  14. Nikon D610 Autofocus Drive Motor Replacement: step 14, image 1 of 2 Nikon D610 Autofocus Drive Motor Replacement: step 14, image 2 of 2
    • This is where having the motherboard off is necessary as the screws we need are burrowed at the very heart of the camera.
    • Four more screws and two ribbon cables marked by the red circles need to be removed to release what we need.
    • The blue circles indicate the screws that don't need to be undone to get to what we need.
  15. Nikon D610 Autofocus Drive Motor Replacement: step 15, image 1 of 2 Nikon D610 Autofocus Drive Motor Replacement: step 15, image 2 of 2
    • At last, the holy grail. We finally have the part that we want.
    • At this point, damage to the camera becomes highly probable if we were to continue to take it apart and we recommend replacing the entire lens housing.
    • We do not recommend tearing down any further as damage is likely to occur.
4 other people completed this guide.
Daniel Eagan
606 Reputation
5 Guides authored
USF Tampa, Team 4-4, Lacy Spring 2016 Member of USF Tampa, Team 4-4, Lacy Spring 2016
USFT-LACY-S16S4G4
3 Members
6 Guides authored
One Comment
I had a D610 where the mirror wouldn't go down properly after is was knocked, I had a look at fixing it but it is basically unserviceable apart from the most basic and superficial repairs repairs, shame really, it was a nice old camera, but to be honest I wasn't surprised. I'm going to buy another second hand and keep the bits for spares or as a memento mori.
Marvin T P Android - Reply
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 37
All Time: 5,698
