Nikon D70 Front Cover Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Nikon D70 Front Cover Replacement, Front Cover: step 1, image 1 of 1
    • Use a plastic opening tool to carefully pry up the flash unit at the point shown in the picture.
  2. Nikon D70 Front Cover Replacement: step 2, image 1 of 1
    • Remove the two 4.3 mm Phillips screws securing the top edge of the front cover to the top cover.
  3. Nikon D70 Front Cover Replacement: step 3, image 1 of 1
    • Remove the two 4.3 mm Phillips screws on the face of the front cover.
  4. Nikon D70 Front Cover Replacement: step 4, image 1 of 1
    • Use the sharp end of a metal spudger or a razor blade to peel the sticker out of the center of the automatic/manual focus switch.
  5. Nikon D70 Front Cover Replacement: step 5, image 1 of 2 Nikon D70 Front Cover Replacement: step 5, image 2 of 2
    • Remove the 6.3 mm shouldered Phillips screw from the center of the automatic/manual focus switch.
    • Pull the automatic/manual focus switch away from the front cover.
  6. Nikon D70 Front Cover Replacement: step 6, image 1 of 1
    • If present, remove the plastic cover from the lens mount.
  7. Nikon D70 Front Cover Replacement: step 7, image 1 of 1
    • Pull the front cover away from the D70.
Finish Line
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,918
