Nikon D80 Bottom Cover Replacement
  1. Nikon D80 Bottom Cover Replacement, Bottom Cover: step 1, image 1 of 2 Nikon D80 Bottom Cover Replacement, Bottom Cover: step 1, image 2 of 2
    • Use the #00 Phillips-head screwdriver to remove the three 8.44 mm screws.
    • Use the #00 Phillips-head screwdriver to remove the four 6.3 mm screws.
    • Use the #00 Phillips-head screwdriver to remove the 2.9 mm screw.
  2. Nikon D80 Bottom Cover Replacement: step 2, image 1 of 2 Nikon D80 Bottom Cover Replacement: step 2, image 2 of 2
    • Use the plastic opening tool to remove the bottom cover.
5 other people completed this guide.
Sara Martin
586 Reputation
4 Guides authored
USF Tampa, Team S1-G1, Leahy Fall 2017 Member of USF Tampa, Team S1-G1, Leahy Fall 2017
USFT-LEAHY-F17S1G1
4 Members
5 Guides authored
One Comment
The shutter make an attempt to work? It has power! I removed the bottom cover all wires are good?
Dale - Reply
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 55
All Time: 3,037
