Nikon D80 Flash Assembly Replacement
  1. Nikon D80 Flash Assembly Replacement, Flash Assembly: step 1, image 1 of 3 Nikon D80 Flash Assembly Replacement, Flash Assembly: step 1, image 2 of 3 Nikon D80 Flash Assembly Replacement, Flash Assembly: step 1, image 3 of 3
    • Press the highlighted button to pop the flash up.
    • Otherwise, use a plastic opening tool to gently lever open the flash by inserting the tool into the gap between the flash and the camera.
  2. Nikon D80 Flash Assembly Replacement: step 2, image 1 of 1
    • Use the #00 Phillips-head screwdriver to remove both 4.20 mm screws by rotating the screwdriver to the left.
  3. Nikon D80 Flash Assembly Replacement: step 3, image 1 of 2 Nikon D80 Flash Assembly Replacement: step 3, image 2 of 2
    • Using a plastic opening tool, pry open the cover.
    • Be advised, some plastic struts may snap off when you remove the cover.
  4. Nikon D80 Flash Assembly Replacement: step 4, image 1 of 2 Nikon D80 Flash Assembly Replacement: step 4, image 2 of 2
    • Using a soldering iron, desolder the orange, tan, and gray wires from the flash assembly.
    • For more information on how to solder and desolder connections, please visit this guide.
    • Use caution while using the hot soldering iron.
  5. Nikon D80 Flash Assembly Replacement: step 5, image 1 of 1
    • Gently remove the flash assembly from the casing.
    • The surface may still be hot, so grab it with caution.
Kevin Horwedel
211 Reputation
1 Guide authored
USF Tampa, Team S1-G1, Leahy Fall 2017 Member of USF Tampa, Team S1-G1, Leahy Fall 2017
USFT-LEAHY-F17S1G1
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 32
All Time: 2,615
