Nikon D80 Main Board Replacement
  1. Nikon D80 Main Board Replacement, Main Board: step 1, image 1 of 2 Nikon D80 Main Board Replacement, Main Board: step 1, image 2 of 2
    • Using a Phillips #00 screwdriver, remove the four 6.2 mm screws from the left and right sides of the outer cover.
  2. Nikon D80 Main Board Replacement: step 2, image 1 of 3 Nikon D80 Main Board Replacement: step 2, image 2 of 3 Nikon D80 Main Board Replacement: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to gently flip the small locking flap of the zero force insertion connector up.
    • Pull the orange connector cable out of the zero force insertion connector using the tweezers.
    • Remove the back cover.
  3. Nikon D80 Main Board Replacement: step 3, image 1 of 3 Nikon D80 Main Board Replacement: step 3, image 2 of 3 Nikon D80 Main Board Replacement: step 3, image 3 of 3
    • Use a Phillips #00 screwdriver to remove the six 3.7 mm screws.
    • Remove the back plate that covers the main board.
  4. Nikon D80 Main Board Replacement: step 4, image 1 of 2 Nikon D80 Main Board Replacement: step 4, image 2 of 2
    • Use a Phillips #00 screwdriver to unscrew the 2.3 mm screw.
  5. Nikon D80 Main Board Replacement: step 5, image 1 of 1
    • Use tweezers to gently flip the small locking flaps of the zero force insertion connectors up.
    • Pull the bottom orange connector cable out of the zero force insertion connector using the tweezers.
    • Pull the top orange connector cable out of the zero force insertion connector using the tweezers.
    • Remove the ribbon cables by gently pulling them away from the no-fuss ribbon cable connectors.
    • Disconnect the main board from the two ports on the left by pulling the main board to the right.
  6. Nikon D80 Main Board Replacement: step 6, image 1 of 3 Nikon D80 Main Board Replacement: step 6, image 2 of 3 Nikon D80 Main Board Replacement: step 6, image 3 of 3
    • Using the soldering iron, disconnect the four wires soldered to the main board.
    • For more information on how to solder and desolder connections, please visit this guide.
    • Be careful when using the hot soldering iron. Move the ribbon cable out of the way as well; it is easy to burn it or yourself when using the iron.
    • Remove the main board.
3 other people completed this guide.
Sara Martin
586 Reputation
4 Guides authored
USF Tampa, Team S1-G1, Leahy Fall 2017 Member of USF Tampa, Team S1-G1, Leahy Fall 2017
USFT-LEAHY-F17S1G1
4 Members
5 Guides authored
One Comment
Is there a Nikon repair forum that might provide more detailed information?
this is the clearest instructions so far but I’m sure there are diagnostic codes for more precise troubleshooting
Mermaid - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 27
All Time: 2,542
