Nikon D90 Bottom Casing Replacement
  1. Nikon D90 Bottom Casing Replacement, Bottom Casing: step 1, image 1 of 1
    • Turn the camera so the bottom casing is facing up.
  2. Nikon D90 Bottom Casing Replacement, Removing  Screws from the Bottom Casing: step 2, image 1 of 2 Nikon D90 Bottom Casing Replacement, Removing  Screws from the Bottom Casing: step 2, image 2 of 2
    • Next, use a PH00 screwdriver to remove the screws from the bottom casing.
    • Remove the four 5.3 mm Phillips screws.
    • Remove the three other 6.3 mm Phillips screws.
    • Be careful not to strip the screws.
  3. Nikon D90 Bottom Casing Replacement, Removing the Bottom Case: step 3, image 1 of 2 Nikon D90 Bottom Casing Replacement, Removing the Bottom Case: step 3, image 2 of 2
    • Next, use a plastic opening tool and carefully pop off the bottom case.
    • Then, lift and remove the bottom case.
4 other people completed this guide.
Matthew Grota
598 Reputation
3 Guides authored
UMass Dartmouth, Team 1-7, Duarte Fall 2014 Member of UMass Dartmouth, Team 1-7, Duarte Fall 2014
UMASSD-DUARTE-F14S1G7
3 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 43
All Time: 5,145
