Nikon D90 Rear Display Buttons Replacement
  1. Nikon D90 Rear Display Buttons Replacement, Removing Casing Screws: step 1, image 1 of 2 Nikon D90 Rear Display Buttons Replacement, Removing Casing Screws: step 1, image 2 of 2
    • Locate the screws on both sides of the camera.
    • Remove the four 6.3 mm Phillips screws using a PH00 screwdriver.
    • Be careful not to strip the screws.
  2. Nikon D90 Rear Display Buttons Replacement, Removing the Rear Casing: step 2, image 1 of 3 Nikon D90 Rear Display Buttons Replacement, Removing the Rear Casing: step 2, image 2 of 3 Nikon D90 Rear Display Buttons Replacement, Removing the Rear Casing: step 2, image 3 of 3
    • Use a plastic opening tool to separate the rear case from the camera.
  3. Nikon D90 Rear Display Buttons Replacement, Disconnecting the Ribbon Cables: step 3, image 1 of 2 Nikon D90 Rear Display Buttons Replacement, Disconnecting the Ribbon Cables: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • After, remove the two orange ribbon connectors attached to the interior of the camera with tweezers.
    • Make sure to remove the ribbon cables carefully from the connectors to avoid damaging the camera.
  4. Nikon D90 Rear Display Buttons Replacement, Removing the Screws from the Rear Casing: step 4, image 1 of 2 Nikon D90 Rear Display Buttons Replacement, Removing the Screws from the Rear Casing: step 4, image 2 of 2
    • Remove the screws from the back assembly with a Phillips (PH00) head screwdriver.
    • Remove the ten 5.3 mm Phillips screws.
    • Remove the three 4.3 mm Phillips screws.
  5. Nikon D90 Rear Display Buttons Replacement, Removing the LCD and other components: step 5, image 1 of 3 Nikon D90 Rear Display Buttons Replacement, Removing the LCD and other components: step 5, image 2 of 3 Nikon D90 Rear Display Buttons Replacement, Removing the LCD and other components: step 5, image 3 of 3
    • Use a plastic opening tool to separate the LCD and metal plates from the casing.
  6. Nikon D90 Rear Display Buttons Replacement, Removing the Display Buttons: step 6, image 1 of 3 Nikon D90 Rear Display Buttons Replacement, Removing the Display Buttons: step 6, image 2 of 3 Nikon D90 Rear Display Buttons Replacement, Removing the Display Buttons: step 6, image 3 of 3
    • Use a plastic opening tool to separate the buttons from the casing.
    • Remove the 4.3 mm Phillips screw from the knob using a PH00 screwdriver.
jonothon cawley
354 Reputation
2 Guides authored
UMass Dartmouth, Team 1-7, Duarte Fall 2014 Member of UMass Dartmouth, Team 1-7, Duarte Fall 2014
UMASSD-DUARTE-F14S1G7
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 15
All Time: 2,603
