Nikon D90 Top Flash Casing Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Nikon D90 Top Flash Casing Replacement, Open the Flash: step 1, image 1 of 3 Nikon D90 Top Flash Casing Replacement, Open the Flash: step 1, image 2 of 3 Nikon D90 Top Flash Casing Replacement, Open the Flash: step 1, image 3 of 3
    • Use a plastic opening tool to lift up the flash.
  2. Nikon D90 Top Flash Casing Replacement, Flash Casing Screws: step 2, image 1 of 2 Nikon D90 Top Flash Casing Replacement, Flash Casing Screws: step 2, image 2 of 2
    • Using a PH00 screwdriver, remove the two 5.3 mm Phillips screws from the flash casing.
    • Be careful not to strip the screw heads.
  3. Nikon D90 Top Flash Casing Replacement, Removing the Top Flash Casing: step 3, image 1 of 3 Nikon D90 Top Flash Casing Replacement, Removing the Top Flash Casing: step 3, image 2 of 3 Nikon D90 Top Flash Casing Replacement, Removing the Top Flash Casing: step 3, image 3 of 3
    • Use a plastic opening tool and carefully pry open the top casing of the flash.
    • Then, lift off the top casing of the flash.
Matthew Grota
598 Reputation
3 Guides authored
UMass Dartmouth, Team 1-7, Duarte Fall 2014 Member of UMass Dartmouth, Team 1-7, Duarte Fall 2014
UMASSD-DUARTE-F14S1G7
3 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 60
