Ninja Coffee Bar® Single-Serve System Frother Replacement
  1. Ninja Coffee Bar® Single-Serve System Frother Replacement, Frother: step 1, image 1 of 2 Ninja Coffee Bar® Single-Serve System Frother Replacement, Frother: step 1, image 2 of 2
    • Remove four 6mm #1 Phillips head screws from under the basket area.
    • Remove the single 6mm #1 Phillips head screw from the side of the unit.
  2. Ninja Coffee Bar® Single-Serve System Frother Replacement: step 2, image 1 of 2 Ninja Coffee Bar® Single-Serve System Frother Replacement: step 2, image 2 of 2
    • Gently pry the upper cover off the unit above the brew basket and above the water reservoir base and along the side of the upper cover.
  3. Ninja Coffee Bar® Single-Serve System Frother Replacement: step 3, image 1 of 2 Ninja Coffee Bar® Single-Serve System Frother Replacement: step 3, image 2 of 2
    • Remove the single 6mm #1 Phillips head screw from the top of the unit. (The two smaller screws should remain attached.)
    • Using an extension, remove the two 6mm Phillips head screws from the side of the frother motor pivot.
  4. Ninja Coffee Bar® Single-Serve System Frother Replacement: step 4, image 1 of 3 Ninja Coffee Bar® Single-Serve System Frother Replacement: step 4, image 2 of 3 Ninja Coffee Bar® Single-Serve System Frother Replacement: step 4, image 3 of 3
    • Pinch power connector and pull lighly to separate.
    • Pull motor straight up to separate from unit.
CJ Berg
444 Reputation
4 Guides authored
One Comment
Awesome write-up. But does anyone know where a replacement frother arm can be purchased?
clarkwolfe - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 1,525
