Ninja Kitchen System Pulse Fan Replacement
  1. Ninja Kitchen System Pulse Fan Replacement, Base Disassembly: step 1, image 1 of 1
    • Take out the three 15 mm Phillips #1 screws.
    • Remove the 15mm T10 screw.
    • Place the 4 screws on the magnetic mat.
  2. Ninja Kitchen System Pulse Fan Replacement: step 2, image 1 of 1
    • Remove the gray base by lifting upwards and placing to the side.
  3. Ninja Kitchen System Pulse Fan Replacement, Fan: step 3, image 1 of 1
    • Remove the central 15 mm length screw, you must hold the fan in place and use a flat head screw driver, twisting counterclockwise.
    • Place this screw on the magnetic mat.
  4. Ninja Kitchen System Pulse Fan Replacement: step 4, image 1 of 2 Ninja Kitchen System Pulse Fan Replacement: step 4, image 2 of 2
    • Remove the fan from the motor by gently pulling upwards.
    • Be careful as to not damage any wires when removing the fan.
    • Set the fan to the side.
3 other people completed this guide.
Cameron Just
391 Reputation
3 Guides authored
USF Tampa, Team 15-1, Remmell Spring 2016 Member of USF Tampa, Team 15-1, Remmell Spring 2016
USFT-REMMELL-S16S15G1
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 901
