Ninja Kitchen System Pulse Motor Replacement
  1. Ninja Kitchen System Pulse Motor Replacement, Base Disassembly: step 1, image 1 of 1
    • Take out the three 15 mm Phillips #1 screws.
    • Remove the 15mm T10 screw.
    • Place the 4 screws on the magnetic mat.
  2. Ninja Kitchen System Pulse Motor Replacement: step 2, image 1 of 1
    • Remove the gray base by lifting upwards and placing to the side.
  3. Ninja Kitchen System Pulse Motor Replacement, Motor: step 3, image 1 of 1
    • Remove the three 15 mm Phillips #1 screws.
    • Place screws on magnetic mat.
  4. Ninja Kitchen System Pulse Motor Replacement: step 4, image 1 of 1
    • Remove the motor by gently lifting up. Be careful with the cords, as they may be tangled.
    • This is the entire motor for the Ninja. If you have access to a spare motor, simply swap out the motors.
2 other people completed this guide.
DJ
122 Reputation
1 Guide authored
USF Tampa, Team 15-1, Remmell Spring 2016 Member of USF Tampa, Team 15-1, Remmell Spring 2016
USFT-REMMELL-S16S15G1
3 Members
5 Guides authored
One Comment
Dear sir my ninga kitchen system 1100 (blender machine) motor rod is broken i need help to replace it where i can get the rod or repair shop near me thank you
Noman - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 14
All Time: 4,337
