Ninja Master Prep QB900B button replacement
Kamal Taha
Kamal Taha and 3 other contributors
Last updated on August 9, 2019
8 minutes
Easy
Action Shots
Introduction
Go to step 1
This guide will teach you how to replace the spring in the button of your blender.
iFixit earns commission when you buy through these links.
  1. Ninja Master Prep QB900B button replacement, The Ninja Master Prep QB900B: step 1, image 1 of 1
    • Place the blender to the side.
  2. Ninja Master Prep QB900B button replacement: step 2, image 1 of 2 Ninja Master Prep QB900B button replacement: step 2, image 2 of 2
    • Remove the two highlighted screws with a Phillips #2 Screw Driver
    • Gently pull off the top.
  3. Ninja Master Prep QB900B button replacement, Button: step 3, image 1 of 1
    • Remove the highlighted screws.
  4. Ninja Master Prep QB900B button replacement: step 4, image 1 of 1
    • Pull out the highlighted spring.
    • Now wash the button with soap and water, and follow the guide backwards to reassemble.
2 other people completed this guide.
Kamal Taha
679 Reputation
5 Guides authored
USF Tampa, Team 1-3, Sullivan Fall 2015 Member of USF Tampa, Team 1-3, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G3
3 Members
5 Guides authored
2 Comments
mine has different screws and they won’t come out easily. looks like it might have a star head. thought it was hex and now the screws are stripped :(
Stephen Filippone - Reply
turns out it was a security torx. how annoying.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 2,017
