Ninja NJ600 Fan Replacement
  1. Ninja NJ600 Fan Replacement, Blender Base Cover: step 1, image 1 of 2 Ninja NJ600 Fan Replacement, Blender Base Cover: step 1, image 2 of 2
    • Remove the five screws (13mm long, 6mm head diameter) using a Phillips #2 screwdriver.
  2. Ninja NJ600 Fan Replacement: step 2, image 1 of 2 Ninja NJ600 Fan Replacement: step 2, image 2 of 2
    • Without removing any screws, you can pull the 2nd layer free from the base. Do this now and set it down gently next to the base.
    • The power cord runs through a hole in the side of this layer. Squeeze the cord and pull it through the hole to separate the layer from the cord.
  3. Ninja NJ600 Fan Replacement: step 3, image 1 of 3 Ninja NJ600 Fan Replacement: step 3, image 2 of 3 Ninja NJ600 Fan Replacement: step 3, image 3 of 3
    • Using the Phillips #2 screwdriver, remove these six screws (13mm long, 6mm head diameter). Then carefully remove this layer, and rest it next to the blender base.
    • Be careful not to damage the two wires that are keeping this third layer attached to the base.
  4. Ninja NJ600 Fan Replacement, Fan: step 4, image 1 of 1
    • Hold the fan steady and use a wrench or pliers to remove the nut in the image.
    • The fan is sharp. Use caution when handling with bare hands.
    • A towel or gloves may be useful when holding the fan for this step.
  5. Ninja NJ600 Fan Replacement: step 5, image 1 of 1
    • Hold the fan and use the flathead 4.0 screwdriver to loosen the washer.
    • The fan is sharp, use caution when handling with bare hands.
    • You may use a towel or gloves to avoid handling the fan with your bare hands.
  6. Ninja NJ600 Fan Replacement: step 6, image 1 of 2 Ninja NJ600 Fan Replacement: step 6, image 2 of 2
    • Slide the washer and fan off of the screw.
Ryan Heller
107 Reputation
1 Guide authored
Cal Poly, Team 24-2, Lancaster Spring 2015 Member of Cal Poly, Team 24-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G2
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 1,378
