Ninja Professional BL610 Button Replacement
  1. Ninja Professional BL610 Button Replacement, Button: step 1, image 1 of 1
    • Remove six screws (12mm long, 6mm head diameter) from bottom of the blender using a Phillips #2 screwdriver.
  2. Ninja Professional BL610 Button Replacement: step 2, image 1 of 1
    • Remove six screws (12mm long, 6mm head diameter) from component housing using Phillips #2 screwdriver.
  3. Ninja Professional BL610 Button Replacement: step 3, image 1 of 1
    • Remove five screws from circuit board using Phillips #2 screwdriver.
  4. Ninja Professional BL610 Button Replacement: step 4, image 1 of 1
    • Once the screws are removed, lift the circuit board to access the back.
  5. Ninja Professional BL610 Button Replacement: step 5, image 1 of 1
    • Locate the button you wish to replace and note its position on the opposite side of the circuit board. They are marked with the letters ¨sw¨ on the circuit board.
  6. Ninja Professional BL610 Button Replacement: step 6, image 1 of 1
    • Using a soldeing gun and soldering wick,desolder the for connection points and remove the button.
Rosniel Castro
482 Reputation
4 Guides authored
USF Tampa, Team S14-G3, Boczar Fall 2017 Member of USF Tampa, Team S14-G3, Boczar Fall 2017
USFT-BOCZAR-F17S14G3
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 223
