Ninja Professional Blender BL660 Blender Base Replacement
  1. Ninja Professional Blender BL660 Blender Base Replacement, Blender Base: step 1, image 1 of 2 Ninja Professional Blender BL660 Blender Base Replacement, Blender Base: step 1, image 2 of 2
    • Using the Phillips #1 screwdriver, remove the 5 screws (13mm long, 6mm wide) holding the outer base.
    • Lift the base up to remove it.
  2. Ninja Professional Blender BL660 Blender Base Replacement: step 2, image 1 of 2 Ninja Professional Blender BL660 Blender Base Replacement: step 2, image 2 of 2
    • Remove the midsection by pulling it up. If the section is stuck, use the iFixit plastic opening tool to pry it off.
    • Pull the power cord through the mid-section opening.
  3. Ninja Professional Blender BL660 Blender Base Replacement: step 3, image 1 of 2 Ninja Professional Blender BL660 Blender Base Replacement: step 3, image 2 of 2
    • Using the Phillips #1 screwdriver, remove the 6 screws (13 mm long, 6 mm wide).
  4. Ninja Professional Blender BL660 Blender Base Replacement: step 4, image 1 of 2 Ninja Professional Blender BL660 Blender Base Replacement: step 4, image 2 of 2
    • Using the Phillips #1 screwdriver, remove the two screws (5 mm long, 3 mm wide) holding the power cord onto the motor cover.
  5. Ninja Professional Blender BL660 Blender Base Replacement: step 5, image 1 of 2 Ninja Professional Blender BL660 Blender Base Replacement: step 5, image 2 of 2
    • Using the iFixit plastic opening tool, pry the motor cover off the general housing. Once it is loose, lift it up to remove it off the base.
    • Slide the cover all the way to the end of the power cord.
    • Please note that the power cord does not completely come off the cover.
0 Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 84
All Time: 2,989
