Ninja Ultima BL810 Power Plug Replacement
  1. Ninja Ultima BL810 Power Plug Replacement, Power Plug: step 1, image 1 of 3 Ninja Ultima BL810 Power Plug Replacement, Power Plug: step 1, image 2 of 3 Ninja Ultima BL810 Power Plug Replacement, Power Plug: step 1, image 3 of 3
    • Unscrew the Phillips #0 11mm screws.
    • Unscrew the Torx Security #10 11mm screw.
  2. Ninja Ultima BL810 Power Plug Replacement: step 2, image 1 of 2 Ninja Ultima BL810 Power Plug Replacement: step 2, image 2 of 2
    • Unscrew the six Phillips #2 11mm screws from the remainder of the bottom plate.
    • Pull the bottom covering off of the blender.
  3. Ninja Ultima BL810 Power Plug Replacement: step 3, image 1 of 2 Ninja Ultima BL810 Power Plug Replacement: step 3, image 2 of 2
    • Unscrew the two Phillips #2 9mm screws.
    • Remove the plastic block.
  4. Ninja Ultima BL810 Power Plug Replacement: step 4, image 1 of 3 Ninja Ultima BL810 Power Plug Replacement: step 4, image 2 of 3 Ninja Ultima BL810 Power Plug Replacement: step 4, image 3 of 3
    • Unscrew the four Phillips #2 11mm screws.
    • Remove the plastic covers.
    • Removing the top cover and then rotating the bottom cover into the same orientation works best.
  5. Ninja Ultima BL810 Power Plug Replacement: step 5, image 1 of 1
    • Unscrew the three Phillips #2 9mm screws.
    • This metal plate doesn't need to be completely removed, just adjusted to the side to continue working.
  6. Ninja Ultima BL810 Power Plug Replacement: step 6, image 1 of 3 Ninja Ultima BL810 Power Plug Replacement: step 6, image 2 of 3 Ninja Ultima BL810 Power Plug Replacement: step 6, image 3 of 3
    • Pull the power cord through as shown to create slack.
    • Remove plastic casing by lifting upwards.
  7. Ninja Ultima BL810 Power Plug Replacement: step 7, image 1 of 3 Ninja Ultima BL810 Power Plug Replacement: step 7, image 2 of 3 Ninja Ultima BL810 Power Plug Replacement: step 7, image 3 of 3
    • Follow the power plug cords to find the right plastic caps.
    • Squeeze the caps with pliers to loosen the grip.
    • Pull the plastic caps off the twisted wires.
  8. Ninja Ultima BL810 Power Plug Replacement: step 8, image 1 of 3 Ninja Ultima BL810 Power Plug Replacement: step 8, image 2 of 3 Ninja Ultima BL810 Power Plug Replacement: step 8, image 3 of 3
    • Untwist the two wires from each other and pull the zip tie off.
Ryan James Gilroy
364 Reputation
3 Guides authored
Cal Poly, Team S9-G4, Banghart Fall 2017 Member of Cal Poly, Team S9-G4, Banghart Fall 2017
CPSU-BANGHART-F17S9G4
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 780
