Nintendo 2DS Wi-Fi Card Replacement
  1. Nintendo 2DS Wi-Fi Card Replacement, Battery: step 1, image 1 of 1
    • Flip over the 2DS.
  2. Nintendo 2DS Wi-Fi Card Replacement: step 2, image 1 of 3 Nintendo 2DS Wi-Fi Card Replacement: step 2, image 2 of 3 Nintendo 2DS Wi-Fi Card Replacement: step 2, image 3 of 3
    • Remove the game cartridge, SD card and stylus if your console has them inserted.
  3. Nintendo 2DS Wi-Fi Card Replacement: step 3, image 1 of 1
    • Undo the 2 Phillips #00 screws.
    • The screws will not completely detach from the battery cover.
  4. Nintendo 2DS Wi-Fi Card Replacement: step 4, image 1 of 2 Nintendo 2DS Wi-Fi Card Replacement: step 4, image 2 of 2
    • Lift the battery cover up and pull it out.
  5. Nintendo 2DS Wi-Fi Card Replacement: step 5, image 1 of 2 Nintendo 2DS Wi-Fi Card Replacement: step 5, image 2 of 2
    • Lift up the battery and remove it.
  6. Nintendo 2DS Wi-Fi Card Replacement, Wi-Fi Card: step 6, image 1 of 1
    • Remove the 10 Phillips #00 screws.
  7. Nintendo 2DS Wi-Fi Card Replacement: step 7, image 1 of 1
    • Carefully remove the rear panel.
    • There's a ribbon cable on the rear panel attached to the motherboard, so be very careful not to damage that cable!
  8. Nintendo 2DS Wi-Fi Card Replacement: step 8, image 1 of 1
    • Pull up the Wi-Fi card from the left side.
  9. Nintendo 2DS Wi-Fi Card Replacement: step 9, image 1 of 1
    • Use a spudger or your fingernail to carefully pull up on the right side of Wi-Fi card. This'll disconnect the Wi-Fi card.
    • There's a cable behind the Wi-Fi card, so be very careful removing it!
  10. Nintendo 2DS Wi-Fi Card Replacement: step 10, image 1 of 1
    • Flip over the Wi-Fi card.
  11. Nintendo 2DS Wi-Fi Card Replacement: step 11, image 1 of 1
    • Use a spudger or your fingernail to remove the cable from the Wi-Fi card.
4 other people completed this guide.
Ella
2,306 Reputation
10 Guides authored
3 Guide Comments
Where is the guide for the 2DS Zelda version? I just opened mine up, and there IS NOT a wifi module card anywhere to be seen?! Did they move it UNDER the motherboard? I can not find any guides to the green and brown Zelda 2DS. Mine won’t update or connect to anything now.
Jeremy Patton - Reply
It is the same. If you cannot see a Wi-Fi card, there probably is no Wi-Fi card.
Ella -
The wifi chip linked is a "2878D-J27H02301" but the one shown in the picture for the 2DS is a "DWM-W082", will either work or do I need to get a DWM-W082?
NullImmer - Reply
Past 24 Hours: 9
Past 7 Days: 59
Past 30 Days: 225
All Time: 6,937
