This guide has more recent changes. Switch to the latest unverified version.
Introduction
If your lower casing is broken you may need to replace it. Be careful to disconnect ribbon cables between the lower casing and the motherboard before removing the lower casing fully.
Unscrew the three 3mm Y0 screws along the right and bottom of the SD card reader.
Tool used on this step:Tweezers$4.99
Reorient the device so that the game slot now faces you.
Remove the two rubber bumpers along the top of the device using tweezers.
Unscrew the seven 6mm Phillips #00 screws along the top and bottom of the 3DS.
