Nintendo 3DS 2015 SD Card Reader Replacement
  1. Nintendo 3DS 2015 SD Card Reader Replacement, Battery: step 1, image 1 of 1
    • Unscrew the two 3mm Phillips #0 head screws along the top edge of the device.
    • The screws on the back panel strip easily. Go slowly and press down firmly.
    • The screws on the back panel are held in by locking washers, so they won't come out of the back panel.
  2. Nintendo 3DS 2015 SD Card Reader Replacement: step 2, image 1 of 2 Nintendo 3DS 2015 SD Card Reader Replacement: step 2, image 2 of 2
    • Pull the top corner tabs of the front face plate outward and towards you.
    • Pull the faceplate up and out of the slots at the bottom of the device.
    • Set aside the back faceplate.
  3. Nintendo 3DS 2015 SD Card Reader Replacement: step 3, image 1 of 3 Nintendo 3DS 2015 SD Card Reader Replacement: step 3, image 2 of 3 Nintendo 3DS 2015 SD Card Reader Replacement: step 3, image 3 of 3
    • Insert a plastic opening tool into the notch at the top of the battery.
    • Pry the battery up with the plastic opening tool.
  4. Nintendo 3DS 2015 SD Card Reader Replacement, SD Card Reader: step 4, image 1 of 1
    • Unscrew the three 3mm Y0 screws along the right and bottom of the SD card reader.
    • The bottom of the SD card reader should slightly pop out after removing the screws.
  5. Nintendo 3DS 2015 SD Card Reader Replacement: step 5, image 1 of 1
    • Pull the SD card reader from the edge with two holes gently to free the tab at the top of the SD card reader.
    • Don't completely pull the SD card out of the device yet. There is a ribbon cable connected under the SD card reader.
    • Reorient the device so that the power jack faces you.
  6. Nintendo 3DS 2015 SD Card Reader Replacement: step 6, image 1 of 2 Nintendo 3DS 2015 SD Card Reader Replacement: step 6, image 2 of 2
    • Lift the SD card reader gently.
    • Use a plastic opening tool to pry the SD card ribbon cable off the socket on the motherboard.
    • Lift the SD card reader out off of the lower casing.
3 other people completed this guide.
Tyler Starr
1,525 Reputation
7 Guides authored
Cal Poly, Team 4-6, Livingston Fall 2016 Member of Cal Poly, Team 4-6, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G6
4 Members
35 Guides authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 32
Past 30 Days: 120
All Time: 4,737
