HTC Desire 510 Front and Main Cameras Replacement
Video Overview
  1. HTC Desire 510 Front and Main Cameras Replacement, BATTERY REMOVAL: step 1, image 1 of 3 HTC Desire 510 Front and Main Cameras Replacement, BATTERY REMOVAL: step 1, image 2 of 3 HTC Desire 510 Front and Main Cameras Replacement, BATTERY REMOVAL: step 1, image 3 of 3
    • Switch off the phone, remove the battery and any installed SIM and memory cards.
    • Remove 7x Torx T5 screws.
  2. HTC Desire 510 Front and Main Cameras Replacement, REAR BEZEL REMOVAL: step 2, image 1 of 3 HTC Desire 510 Front and Main Cameras Replacement, REAR BEZEL REMOVAL: step 2, image 2 of 3 HTC Desire 510 Front and Main Cameras Replacement, REAR BEZEL REMOVAL: step 2, image 3 of 3
    • Use a plastic tool to remove the rear bezel.
    • The loudspeaker is on the inner side of the rear bezel.
  3. HTC Desire 510 Front and Main Cameras Replacement, FLEX CABLES DISCONNECTING: step 3, image 1 of 3 HTC Desire 510 Front and Main Cameras Replacement, FLEX CABLES DISCONNECTING: step 3, image 2 of 3 HTC Desire 510 Front and Main Cameras Replacement, FLEX CABLES DISCONNECTING: step 3, image 3 of 3
    • Disconnect the touch screen flex cable.
    • Disconnect the light sensor flex cable.
    • Unstuck the vibra-motor from the middle frame.
    • Remove the coaxial antenna cable from the middle frame.
    • The LCD display flex cable is connected to the bottom side of the board.
  4. HTC Desire 510 Front and Main Cameras Replacement, LOGIC BOARD REMOVAL: step 4, image 1 of 3 HTC Desire 510 Front and Main Cameras Replacement, LOGIC BOARD REMOVAL: step 4, image 2 of 3 HTC Desire 510 Front and Main Cameras Replacement, LOGIC BOARD REMOVAL: step 4, image 3 of 3
    • At the upper left side, the board is held by a plastic locking clip. Use a plastic tool and start the separating from here.
    • Gently disconnect the LCD display flex cable.
    • Now remove the logic board.
  5. HTC Desire 510 Front and Main Cameras Replacement, Front and Main Cameras: step 5, image 1 of 2 HTC Desire 510 Front and Main Cameras Replacement, Front and Main Cameras: step 5, image 2 of 2
    • Main / Rear camera.
    • New line.
2 other people completed this guide.
ZFix
196,388 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
332 Members
1,473 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 40
All Time: 1,705
