Nintendo 64 Rumble Pak Battery Replacement
  1. Nintendo 64  Rumble Pak Battery Replacement, Rumble Pak Battery: step 1, image 1 of 1
    • Remove the Rumble Pak from the controller by pressing the release button and pulling the Rumble Pak out.
  2. Nintendo 64  Rumble Pak Battery Replacement: step 2, image 1 of 1
    • Remove the battery cover from the Rumble Pak by pressing the tab and pulling the cover up.
  3. Nintendo 64  Rumble Pak Battery Replacement: step 3, image 1 of 1
    • Press each battery toward the spring, then pull toward you to remove the batteries from the Rumble Pak.
    • When inserting the new batteries, make sure the positive (+) end of the battery touches the flat piece, and the negative (-) end touches the spring.
  4. Nintendo 64  Rumble Pak Battery Replacement: step 4, image 1 of 3 Nintendo 64  Rumble Pak Battery Replacement: step 4, image 2 of 3 Nintendo 64  Rumble Pak Battery Replacement: step 4, image 3 of 3
    • Check for corrosion around the springs and the flat plate where the batteries touch.
    • Do not touch the corrosion. It may be battery acid.
    • Use a flat head screwdriver to chisel away the corrosion, and use a Q-tip to wipe it clean.
    • Do not use water to wet the Q-tip, as water can damage the Rumble Pak.
Carly Bowen
312 Reputation
1 Guide authored
Texas Tech, Team 3-6, Rauch SU 2015 Member of Texas Tech, Team 3-6, Rauch SU 2015
TTU-RAUCH-SU15S3G6
3 Members
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 59
All Time: 4,754
