Nintendo 64 Top Cover Replacement
  1. Nintendo 64 Top Cover Replacement, Top Cover: step 1, image 1 of 1
    • Remove the expansion pack cover by pushing in the tab and pulling out.
  2. Nintendo 64 Top Cover Replacement: step 2, image 1 of 1
    • If your system uses a jumper pack, the same procedure applies to remove it.
    • A small spoon can be used in place of a spudger.
    • Lever the expansion pack out using a metal spudger.
  3. Nintendo 64 Top Cover Replacement: step 3, image 1 of 1
    • Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
  4. Nintendo 64 Top Cover Replacement: step 4, image 1 of 1
    • Remove the two front feet of the N64.
  5. Nintendo 64 Top Cover Replacement: step 5, image 1 of 1
    • Rotate to top side up and lift off top cover.
23 other people completed this guide.
bbdiamond13
432 Reputation
1 Guide authored
Cal Poly, Team 5-4, Regan Fall 2009 Member of Cal Poly, Team 5-4, Regan Fall 2009
CPSU-REGAN-F09S5G4
7 Members
20 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 109
All Time: 45,207
