Nintendo DS Back Panel Replacement
  1. Nintendo DS Back Panel Replacement, Battery: step 1, image 1 of 3 Nintendo DS Back Panel Replacement, Battery: step 1, image 2 of 3 Nintendo DS Back Panel Replacement, Battery: step 1, image 3 of 3
    • Remove the cartridge from the console.
    • Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
    • Remove the battery door.
    • In the images, it shows that the fixer is using a flathead screwdriver. This flathead screwdriver will work just like the Phillips #00 Screwdriver.
  2. Nintendo DS Back Panel Replacement: step 2, image 1 of 1
    • Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic opening tool or spudger isn't available, your fingernails may work.
  3. Nintendo DS Back Panel Replacement: step 3, image 1 of 1
    • Remove the battery from the Nintendo DS.
  4. Nintendo DS Back Panel Replacement, Back Panel: step 4, image 1 of 1
    • Remove the seven 6.4mm Y00 screws located on the back.
    • If your DS has a lanyard attached to it, you can remove it to make the process of opening the top-left screw easier.
  5. Nintendo DS Back Panel Replacement: step 5, image 1 of 3 Nintendo DS Back Panel Replacement: step 5, image 2 of 3 Nintendo DS Back Panel Replacement: step 5, image 3 of 3
    • With your hands, pry the back panel off the main case.
    • Separate the back from the front, and set it aside.
18 other people completed this guide.
dnguye26
746 Reputation
4 Guides authored
Cal Poly, Team 18-3, Maness Fall 2009 Member of Cal Poly, Team 18-3, Maness Fall 2009
CPSU-MANESS-F09S18G3
4 Members
31 Guides authored
2 Guide Comments
Where do I get a nintendo DS gamepak?
Kayla Maison - Reply
Kayla Maison , a gamepak is simply a GBA game.
Bob - Reply
Past 24 Hours: 7
Past 7 Days: 39
Past 30 Days: 193
All Time: 20,282
