Nintendo DS Lite Lower LCD Assembly Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Nintendo DS Lite Lower LCD Assembly Replacement, Lower LCD Assembly: step 1, image 1 of 2 Nintendo DS Lite Lower LCD Assembly Replacement, Lower LCD Assembly: step 1, image 2 of 2
    • Use your fingernail or the edge of a plastic opening tool to carefully flip up the lower LCD ribbon cable retaining flap.
    • Make sure you are flipping up the retaining flap, not the socket itself.
    • Pull the lower LCD assembly straight away to separate the lower LCD ribbon cable from its socket on the motherboard.
    • Remove the lower LCD assembly from the motherboard.
    • When reinstalling lower LCD, ensure it has insulation on the back to prevent a short circuit with the motherboard.
Matthew Newsom
41,999 Reputation
67 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 610
