Nintendo DS Lite Shoulder Buttons Replacement
Introduction
Go to step 1This guide will explain how to replace the shoulder buttons on a DS Lite if they are sticking or not working properly.
The tools you’ll need for this task are:
- Spudger or other flat tool
- Screwdrivers
- Phillips
- Tri-wing
Use a Phillips #00 screwdriver to remove the screw securing the battery cover.
Use a spudger to pry out the battery.
Pry off the rubber feet.
Remove the seven screws securing the lower case:
Three tri-wing screws
One Phillips screw
Two gold Phillips screws
One black tri-wing screw
2 Phillips screws at the battery
pretty sure that holds the board in place, you dont need to unscrew it and you probably shouldnt
You can now access the micro-button component and replace or repair anything as needed.
Could someone run through or send a link explaining the disassembly of the micro-button?
This explains how to disassemble the system, but has nothing about actually replacing the shoulder buttons. I got this far and found the R button has a ribbon cable port directly on the other side of the board, so I hoped to find something in here showing how to remove the button properly before putting the replacement in.
To reassemble your device, follow the steps in reverse order after making your repair.
7 other people completed this guide.
5 Comments
For anyone dealing with unresponsive shoulder buttons, I highly recommend watching this video guide;
https://www.youtube.com/watch?v=VnWdawXC...
たしかにそうですね!!!
kawagoe -
Thanks, this was very helpful. The ifixit guide doesn't include the needed details of how to clean the button contact. This fixed my issue.
+1 on this! Didn't need to replace the button at all.
Isak -
