Nintendo DSi Battery Board/Fuse Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Careful: steps 1-2 are sourced from a guide that's marked as in-progress.
    Nintendo DSi Battery Board/Fuse Replacement, Battery: step 1, image 1 of 1
    • Loosen the two screws on the battery panel. Then lift the panel up to remove it.
  2. Nintendo DSi Battery Board/Fuse Replacement: step 2, image 1 of 1
    • L Button.
    • Top of the battery pack.
    • To remove the battery pack, place your fingernail or a spudger at the top of the battery near the L button. Gently lift the battery out.
  3. Nintendo DSi Battery Board/Fuse Replacement, Lower Case Assembly: step 3, image 1 of 2 Nintendo DSi Battery Board/Fuse Replacement, Lower Case Assembly: step 3, image 2 of 2
    • Two screws are hidden underneath two rubber feet highlighted in red.
    • Use the tip of a spudger to pry the rubber feet out of the lower case.
    • Depending on the age of your device, the rubber feet may crumble apart as you pry them out. If so, use a fine-tipped tool to scrape out any stuck pieces of rubber.
  4. Nintendo DSi Battery Board/Fuse Replacement: step 4, image 1 of 1
    • Remove the following screws securing the lower case to the body of the DSi:
    • Six 5.2 mm Phillips #00 screws.
    • One 2.7 mm Phillips #00 screw.
  5. Nintendo DSi Battery Board/Fuse Replacement: step 5, image 1 of 3 Nintendo DSi Battery Board/Fuse Replacement: step 5, image 2 of 3 Nintendo DSi Battery Board/Fuse Replacement: step 5, image 3 of 3
    • Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
    • Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
    • Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
  6. Nintendo DSi Battery Board/Fuse Replacement: step 6, image 1 of 2 Nintendo DSi Battery Board/Fuse Replacement: step 6, image 2 of 2
    • Carefully lift the lower casing from its bottom edge.
    • The lower case is still attached to the motherboard by the volume and SD board cable highlighted in red. Do not try to completely remove the lower case of the DSi yet.
    • Pry the volume and SD board cable up from its socket on the motherboard using a spudger.
    • Once the cable is completely removed, then you may take off the entire outer casing.
  7. Careful: steps 7-8 are sourced from a guide that's marked as in-progress.
    Nintendo DSi Battery Board/Fuse Replacement, Disconnecting Nintendo DSi Battery Board: step 7, image 1 of 1
    • Flip up the black latch and disconnect the D-Pad/Power Button ribbon cable.
  8. Nintendo DSi Battery Board/Fuse Replacement: step 8, image 1 of 3 Nintendo DSi Battery Board/Fuse Replacement: step 8, image 2 of 3 Nintendo DSi Battery Board/Fuse Replacement: step 8, image 3 of 3
    • The power connector (with red and black wires) is difficult to remove without damaging it, unless you take a moment and understand how it works. Look at all of the photos for this step before continuing.
    • The connector is two pieces -- a white "male" piece (connected to the wires), and a beige "female" part (soldered to the main board).
    • There is a small "notch" in the female part, to give you a place to insert a small flat-head screwdriver. Put the corner of your screwdriver in there, and twist it gently to push the white part up (away from the main board). Do not try to pull it to the right (towards the battery board).
    • If it does not lift easily, try again with a smaller screwdriver. You might be pulling the female connector off the board, which will be difficult to repair.
  9. Nintendo DSi Battery Board/Fuse Replacement, Battery Board/Fuse: step 9, image 1 of 1
    • Remove 5 2.6 mm Phillips #00 screws.
  10. Nintendo DSi Battery Board/Fuse Replacement: step 10, image 1 of 3 Nintendo DSi Battery Board/Fuse Replacement: step 10, image 2 of 3 Nintendo DSi Battery Board/Fuse Replacement: step 10, image 3 of 3
    Tool used on this step:
    Buy
    • Insert a 1.5mm flat-head screwdriver into the notch to the right of the LED assembly, and pry the black plastic frame out of the case.
    • Using some tweezers to pull out the clear plastic light pipe assembly.
    • The orange flex cable (with the LEDs) is attached to the black plastic frame with adhesive; if you accidentally pull the cable off the plastic frame, pull the plastic frame and light pipe out with tweezers and reassemble them.
  11. Nintendo DSi Battery Board/Fuse Replacement: step 11, image 1 of 1
    • Remove the battery board and LED assembly, and flip them over.
    • If either of the two flex ribbon cables have been disconnected or damaged, use a spudger to flip the black latch up (away from the board), remove the cable, reinsert it, and press the latch down.
    • If your console does not power on, use an ohmmeter/continuity checker to test the SMT fuse F1. It should read as 0 ohms (short circuit). If not, you will need to replace the fuse or replace the board.
    • You must replace this fuse with an 0603 SMT fuse. Do not attempt to replace the fuse if you are not familiar with soldering 0603 SMT parts; instead, replace the whole board. Replacing the fuse with a 0-ohm resistor or a piece of wire is not recommended.
    • If you are stopping here, follow these instructions in reverse order to reassemble your device.
bushing
10,289 Reputation
13 Guides authored
One Comment
When i changed my housing and reassembling, the DSi won’t turn on
trace back the problems and it ended up in this battery board (i change it with another battery board and it was okay)
my question is: what prevents my DSi from turning on? i checked all the ribbon cables and the battery cable below and everything was fine
i need it for my 2nd DSi, thanks in advance
Andhika Cikal - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 21,074
