Nintendo DSi Trigger Button/SD Board Assembly
  1. Nintendo DSi Trigger Button/SD Board Assembly, Battery Cover Removal: step 1, image 1 of 2 Nintendo DSi Trigger Button/SD Board Assembly, Battery Cover Removal: step 1, image 2 of 2
    • Unscrew the two Phillips screws securing the battery cover to the lower case.
    • The screws remain captive to the battery cover.
    • Grasp the battery cover and lift it out of the lower case.
    • If it's difficult to grasp, lightly tap the opposite side of the device.
  2. Nintendo DSi Trigger Button/SD Board Assembly, Taking out the Battery: step 2, image 1 of 2 Nintendo DSi Trigger Button/SD Board Assembly, Taking out the Battery: step 2, image 2 of 2
    • Using a spudger tool (or your fingernail), lift up the battery from the top.
    • There's a small tab on the top of the battery to make removal easier.
    • The liquid damage indicator sits underneath the battery. Pry gently, or you may damage the indicator.
    • Grasp the battery and remove it from the DSi.
  3. Nintendo DSi Trigger Button/SD Board Assembly, Lower Case Assembly: step 3, image 1 of 2 Nintendo DSi Trigger Button/SD Board Assembly, Lower Case Assembly: step 3, image 2 of 2
    • Two screws are hidden underneath two rubber feet highlighted in red.
    • Use the tip of a spudger to pry the rubber feet out of the lower case.
    • Depending on the age of your device, the rubber feet may crumble apart as you pry them out. If so, use a fine-tipped tool to scrape out any stuck pieces of rubber.
  4. Nintendo DSi Trigger Button/SD Board Assembly: step 4, image 1 of 1
    • Remove the following screws securing the lower case to the body of the DSi:
    • Six 5.2 mm Phillips #00 screws.
    • One 2.7 mm Phillips #00 screw.
  5. Nintendo DSi Trigger Button/SD Board Assembly: step 5, image 1 of 3 Nintendo DSi Trigger Button/SD Board Assembly: step 5, image 2 of 3 Nintendo DSi Trigger Button/SD Board Assembly: step 5, image 3 of 3
    • Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
    • Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
    • Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
  6. Nintendo DSi Trigger Button/SD Board Assembly: step 6, image 1 of 2 Nintendo DSi Trigger Button/SD Board Assembly: step 6, image 2 of 2
    • Carefully lift the lower casing from its bottom edge.
    • The lower case is still attached to the motherboard by the volume and SD board cable highlighted in red. Do not try to completely remove the lower case of the DSi yet.
    • Pry the volume and SD board cable up from its socket on the motherboard using a spudger.
    • Once the cable is completely removed, then you may take off the entire outer casing.
  7. Nintendo DSi Trigger Button/SD Board Assembly, Stylus Housing: step 7, image 1 of 1
    • Pull the stylus straight out its housing and remove it from the rear case.
  8. Nintendo DSi Trigger Button/SD Board Assembly: step 8, image 1 of 1
    • Remove the five 3.9 mm Phillips screws securing the stylus holder to the rear case.
  9. Nintendo DSi Trigger Button/SD Board Assembly: step 9, image 1 of 2 Nintendo DSi Trigger Button/SD Board Assembly: step 9, image 2 of 2
    • Lift and remove the left plastic protector from the DSi's rear case.
    • Grasp the stylus holder from the left side and lift upwards to remove it from the DSi.
  10. Nintendo DSi Trigger Button/SD Board Assembly, Trigger Button and SD Board Assembly: step 10, image 1 of 1
    • Lift the right trigger button cover out of the rear case.
  11. Nintendo DSi Trigger Button/SD Board Assembly: step 11, image 1 of 2 Nintendo DSi Trigger Button/SD Board Assembly: step 11, image 2 of 2
    • Lift and dislodge the SD board from its housing within the rear case.
    • Peel the trigger buttons/SD board cable of its channel in the rear case.
  12. Nintendo DSi Trigger Button/SD Board Assembly: step 12, image 1 of 3 Nintendo DSi Trigger Button/SD Board Assembly: step 12, image 2 of 3 Nintendo DSi Trigger Button/SD Board Assembly: step 12, image 3 of 3
    • Lift the steel battery tray out of the lower case and remove the trigger button/SD board assembly.
    • When removing the trigger button/SD board assembly, don't lose the two steel nuts (highlighted in red) inserted into the lower case.
    • If your trigger button happens to fall apart during diassembly, the third picture shows its correct installed orientation. Be sure the spring is installed in the position shown, and that the two trigger button covers are unique to the side they are supposed to be installed in.
37 other people completed this guide.
4 Guide Comments
I noticed some pencil marks on the inside of the lower shell that must have come from the factory. There is an m/ to the right of the foam pad, an ax to the right of that, and some kind of numeric marking that says 1T7 12 above the ribbon cable. I'm wondering if it has any significance.
Matthew Maulding - Reply
Hi! I accidentally stripped the screws above the game slot , any ideas how to unscrew it without breaking my dsi?
Akbar Afandi - Reply
Since it doesn't explain how to remove the volume input, you can gently pry it off with a spudger.
Shard !! - Reply
THANK YOU, when I got to that part I had no idea how to remove it, I was afraid I'd break something important.
Alec -
Past 24 Hours: 15
Past 7 Days: 122
Past 30 Days: 451
All Time: 37,260
