Nintendo DSi XL Lower LCD Replacement
David Hodson
David Hodson and 5 other contributors
Last updated on July 16, 2024
No estimate
Moderate
Featured Guide
Introduction
Go to step 1
See the action on your DSi XL with a new lower LCD screen.
Parts
Tools
Show more…
iFixit earns commission when you buy through these links.
  1. Nintendo DSi XL Lower LCD Replacement, Battery: step 1, image 1 of 2 Nintendo DSi XL Lower LCD Replacement, Battery: step 1, image 2 of 2
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Nintendo DSi XL Lower LCD Replacement: step 2, image 1 of 1
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Lower LCD Replacement, Lower Case: step 3, image 1 of 3 Nintendo DSi XL Lower LCD Replacement, Lower Case: step 3, image 2 of 3 Nintendo DSi XL Lower LCD Replacement, Lower Case: step 3, image 3 of 3
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Nintendo DSi XL Lower LCD Replacement: step 4, image 1 of 1
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Nintendo DSi XL Lower LCD Replacement: step 5, image 1 of 3 Nintendo DSi XL Lower LCD Replacement: step 5, image 2 of 3 Nintendo DSi XL Lower LCD Replacement: step 5, image 3 of 3
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Nintendo DSi XL Lower LCD Replacement: step 6, image 1 of 2 Nintendo DSi XL Lower LCD Replacement: step 6, image 2 of 2
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Nintendo DSi XL Lower LCD Replacement: step 7, image 1 of 2 Nintendo DSi XL Lower LCD Replacement: step 7, image 2 of 2
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Nintendo DSi XL Lower LCD Replacement, Wi-Fi Board: step 8, image 1 of 2 Nintendo DSi XL Lower LCD Replacement, Wi-Fi Board: step 8, image 2 of 2
    • Lift the Wi-Fi board up off its socket on the motherboard.
    • Do not attempt to completely remove the Wi-Fi board yet. It is attached to the motherboard by an antenna cable.
  9. Nintendo DSi XL Lower LCD Replacement: step 9, image 1 of 1
    • Use a spudger to pry the Wi-Fi cable off its socket on the underside of the Wi-Fi board.
  10. Nintendo DSi XL Lower LCD Replacement, Motherboard: step 10, image 1 of 1
    • Use a spudger to pry the microphone cable off the motherboard.
    • Pry from underneath the cable.
  11. Nintendo DSi XL Lower LCD Replacement: step 11, image 1 of 2 Nintendo DSi XL Lower LCD Replacement: step 11, image 2 of 2
    • Using the flat end of a spudger, flip up the retaining flap on the camera ribbon ZIF connector.
    • Use the pointed end of a spudger to pull the camera ribbon from the ZIF connector.
  12. Nintendo DSi XL Lower LCD Replacement: step 12, image 1 of 2 Nintendo DSi XL Lower LCD Replacement: step 12, image 2 of 2
    • Using the flat end of a spudger, flip up the retaining flap on the touchscreen cable ZIF connector.
    • With the pointed end of the spudger, pull the touchscreen cable from its connector on the motherboard.
  13. Nintendo DSi XL Lower LCD Replacement: step 13, image 1 of 2 Nintendo DSi XL Lower LCD Replacement: step 13, image 2 of 2
    • Using the flat end of a spudger, flip up the retaining flap on the backlight cable ZIF connector.
    • With the pointed end of the spudger, pull the backlight cable from its connector on the motherboard.
  14. Nintendo DSi XL Lower LCD Replacement: step 14, image 1 of 2 Nintendo DSi XL Lower LCD Replacement: step 14, image 2 of 2
    • Using the flat end of a spudger, flip up the retaining flap on the lower display data cable ZIF connector.
    • With the pointed end of the spudger, pull the lower display data cable from its connector on the motherboard.
  15. Nintendo DSi XL Lower LCD Replacement: step 15, image 1 of 2 Nintendo DSi XL Lower LCD Replacement: step 15, image 2 of 2
    • Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-Pad/power button cable.
    • With the pointed end of the spudger, pull the D-Pad/power button cable from its connector on the motherboard.
  16. Nintendo DSi XL Lower LCD Replacement: step 16, image 1 of 1
    • Using the flat end of the spudger, pry the battery cable up off its socket on the motherboard.
  17. Nintendo DSi XL Lower LCD Replacement: step 17, image 1 of 1
    • Remove the screws securing the motherboard to the upper case:
    • A single 2.5 mm silver Phillips screw
    • Four 3.7 mm black Phillips screws
  18. Nintendo DSi XL Lower LCD Replacement: step 18, image 1 of 1
    • Deroute the microphone and antenna cables through the slot in the motherboard.
  19. Nintendo DSi XL Lower LCD Replacement: step 19, image 1 of 2 Nintendo DSi XL Lower LCD Replacement: step 19, image 2 of 2
    • Rotate the motherboard off the lower case.
    • The motherboard cannot be completely removed yet. It is still attached by the upper LCD's display data ribbon cable.
  20. Nintendo DSi XL Lower LCD Replacement: step 20, image 1 of 2 Nintendo DSi XL Lower LCD Replacement: step 20, image 2 of 2
    • Using the flat end of a spudger, flip up the retaining flap on the upper display data cable ZIF connector.
    • With the pointed end of the spudger, pull the upper display data cable from its connector on the underside of the motherboard.
    • The motherboard is now free from the upper case.
  21. Nintendo DSi XL Lower LCD Replacement, Lower Display Assembly: step 21, image 1 of 2 Nintendo DSi XL Lower LCD Replacement, Lower Display Assembly: step 21, image 2 of 2
    • With the console still upside-down, open the DSi XL slightly.
    • Push the lower display away from the upper case.
    • Remove the lower display from the DSi XL.
  22. Nintendo DSi XL Lower LCD Replacement, Lower LCD: step 22, image 1 of 2 Nintendo DSi XL Lower LCD Replacement, Lower LCD: step 22, image 2 of 2
    • Insert a spudger between the touchscreen and top right corner of the display.
    • Slide the spudger down the right side of the display to free the edge of the touchscreen.
  23. Nintendo DSi XL Lower LCD Replacement: step 23, image 1 of 2 Nintendo DSi XL Lower LCD Replacement: step 23, image 2 of 2
    • Continue around the bottom right corner of the display with the spudger.
    • Slide the spudger along the bottom edge of the touchscreen to separate it from the display.
  24. Nintendo DSi XL Lower LCD Replacement: step 24, image 1 of 2 Nintendo DSi XL Lower LCD Replacement: step 24, image 2 of 2
    • Continue around the bottom left corner of the display with a spudger.
    • Slide the spudger along the left edge of the touchscreen to remove it from the display.
  25. Nintendo DSi XL Lower LCD Replacement: step 25, image 1 of 2 Nintendo DSi XL Lower LCD Replacement: step 25, image 2 of 2
    • With three sides freed, remove the touchscreen from the lower display.
15 other people completed this guide.
David Hodson
152,733 Reputation
127 Guides authored
3 Comments
DSI XL Lower LCD ZIF Socket replacement - Please help!!
Hi All, I have a DSi XL which i am trying to rescue from someone who has done a bad job of attempting a repair! It has been taken apart, although the guy didn't know how ZIF sockets work and has broken two of them. The 37 pin Lower LCD ZIF socket, and the 15 pin power board ZIF socket. I am experienced electronic engineer and and hand soldered SMD components before so i think i can replace these and get this DSi working again. My only problem is, i cannot find any reference to exactly what these sockets are or where to buy some! Can anyone offer any information about these sockets at all? I really want to get hold of some and get this back in action. Any help locatin the correct parts would be very very welcomed.
Many thanks in advance all
Matt Stroud
mattstroud - Reply
Great set of instructions - Thanks
Replaced the lower screen for the first time with no problems
Thanks
Roy Bastiman - Reply
Hello and thanks for sharing.
I have two units of this model.
The first one sunk in water and I’m not sure it can be fixed (can it?)
The other one’s lower screen got a slight crack when it was hit by the kids using it with the device pen, and the touch response has been limited since. I was wondering if I can take out only the touch layer of the sunken device’s screen and install it on the new one.
Thanks.
Shimmy Weitzhandler - Reply
Past 24 Hours: 2
Past 7 Days: 38
Past 30 Days: 166
All Time: 18,527
