Nintendo DSi XL Volume Buttons Replacement
  1. Nintendo DSi XL Volume Buttons Replacement, Battery: step 1, image 1 of 2 Nintendo DSi XL Volume Buttons Replacement, Battery: step 1, image 2 of 2
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Nintendo DSi XL Volume Buttons Replacement: step 2, image 1 of 1
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Volume Buttons Replacement, Lower Case: step 3, image 1 of 3 Nintendo DSi XL Volume Buttons Replacement, Lower Case: step 3, image 2 of 3 Nintendo DSi XL Volume Buttons Replacement, Lower Case: step 3, image 3 of 3
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Nintendo DSi XL Volume Buttons Replacement: step 4, image 1 of 1
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Nintendo DSi XL Volume Buttons Replacement: step 5, image 1 of 3 Nintendo DSi XL Volume Buttons Replacement: step 5, image 2 of 3 Nintendo DSi XL Volume Buttons Replacement: step 5, image 3 of 3
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Nintendo DSi XL Volume Buttons Replacement: step 6, image 1 of 2 Nintendo DSi XL Volume Buttons Replacement: step 6, image 2 of 2
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Nintendo DSi XL Volume Buttons Replacement: step 7, image 1 of 2 Nintendo DSi XL Volume Buttons Replacement: step 7, image 2 of 2
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Nintendo DSi XL Volume Buttons Replacement, Volume Control Switch: step 8, image 1 of 1
    • On the inside of the battery compartment, use the tip of a spudger to detach the metal latch securing the volume control switch in place.
    • The latch will only move about 1 mm.
  9. Nintendo DSi XL Volume Buttons Replacement: step 9, image 1 of 3 Nintendo DSi XL Volume Buttons Replacement: step 9, image 2 of 3 Nintendo DSi XL Volume Buttons Replacement: step 9, image 3 of 3
    • Using the flat end of a spudger, remove the adhesive securing the volume control switch ribbon cable to the back of the battery compartment.
    • Using the flat of a spudger, pry the volume control switch straight up out of the lower case.
    • Remove the volume control switch from the DSi XL.
  10. Nintendo DSi XL Volume Buttons Replacement: step 10, image 1 of 1
    • Using the flat end of a spudger, remove the volume control buttons from the metal backing bracket.
    • The bracket is attached by a strong adhesive. Work slowly and carefully, being sure to not damage the ribbon cable.
    • Volume control switch remains.
  11. Nintendo DSi XL Volume Buttons Replacement, Volume Buttons: step 11, image 1 of 3 Nintendo DSi XL Volume Buttons Replacement, Volume Buttons: step 11, image 2 of 3 Nintendo DSi XL Volume Buttons Replacement, Volume Buttons: step 11, image 3 of 3
    Tool used on this step:
    Buy
    • While pushing the volume buttons through their holes in the lower case, remove the buttons and their silicone pads with a pair of tweezers.
    • Work patiently and carefully as the silicone pad is easily torn.
    • Remove the buttons from the silicone pad.
Brett Hartt
131,269 Reputation
143 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,828 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 34
Past 30 Days: 88
All Time: 8,136
