Nintendo Entertainment System Controller Cable Replacement
  1. Nintendo Entertainment System Controller Cable Replacement, Back Cover Removal: step 1, image 1 of 2 Nintendo Entertainment System Controller Cable Replacement, Back Cover Removal: step 1, image 2 of 2
    • Remove the 6 8mm screws in the back cover using a #1 Philips screwdriver.
  2. Nintendo Entertainment System Controller Cable Replacement, Loosen Cable: step 2, image 1 of 1
    • Lift the back cover off the controller.
    • Remove the cable from its holders to facilitate PCB removal.
  3. Nintendo Entertainment System Controller Cable Replacement, PCB Removal: step 3, image 1 of 1
    • Lift the PCB straight up and out of the controller. Turn the board over to access the solder joints for the cable.
    • Desolder the 5 connections and solder in your new cable.
    • Wire colors are printed on the reverse side of the board.
themap504
80 Reputation
1 Guide authored
2 Guide Comments
My replacement plugs have different colors. Colors are yellow, white, red, black, and green. I’m also doing a max controller not regular nes controller. The max has yellow, red, white, red, and orange color schemes. Any advice. I wired up same colors and guessed for rest. figured black could replace one of the reds, and used green to replace orange, but console just resets over and over with that controller plugged in.
Daniel Melvin - Reply
Check for continuity from the pins on the plug side with the wires and soldier them in the corresponding spot, i:e if red is power then you soldier it to the power slot on the motherboard and so on. Check if you can find a instruction book on the controller.
Cgull - Reply
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 43
All Time: 2,630
