Nintendo Game Boy Advance SP Power Switch Cover Replacement
  1. Nintendo Game Boy Advance SP Power Switch Cover Replacement, Battery: step 1, image 1 of 1
    • Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
  2. Nintendo Game Boy Advance SP Power Switch Cover Replacement: step 2, image 1 of 1
    • Lift the battery cover up and remove it from the device.
    • The screw will remain attached to the battery cover because of Nintendo's design.
  3. Nintendo Game Boy Advance SP Power Switch Cover Replacement: step 3, image 1 of 1
    • Use your fingers or a plastic opening tool to remove the battery from the device.
    • Caution: Please exercise caution when handling the battery. If it appears to be swelling or damaged at all it is considered a fire hazard.
  4. Nintendo Game Boy Advance SP Power Switch Cover Replacement, Back Cover: step 4, image 1 of 2 Nintendo Game Boy Advance SP Power Switch Cover Replacement, Back Cover: step 4, image 2 of 2
    • Remove four 6.5 mm screws from the corners of the back cover using a tri-point Y00 screwdriver.
    • Remove two 4.6mm screws from the top-center and bottom-center of the device using a tri-point Y00 screwdriver.
  5. Nintendo Game Boy Advance SP Power Switch Cover Replacement: step 5, image 1 of 1
    • Lift the back cover off of the device.
    • Potential for device damage: These inner components are vulnerable to static electricity. Exercise caution when handling these next steps to prevent damaging the device.
    • Look out for the power switch that can fall out when taking the back cover off.
  6. Nintendo Game Boy Advance SP Power Switch Cover Replacement, Power Switch Cover: step 6, image 1 of 2 Nintendo Game Boy Advance SP Power Switch Cover Replacement, Power Switch Cover: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Lift the power switch cover away from the left side of the device using your fingers or tweezers.
17 other people completed this guide.
DJ Pantone
1,924 Reputation
5 Guides authored
Cal Poly, Team 17-22, Forte Winter 2013 Member of Cal Poly, Team 17-22, Forte Winter 2013
CPSU-FORTE-W13S17G22
4 Members
39 Guides authored
One Comment
This doesn't explain anything about how to replace the switch
Michael - Reply
Past 24 Hours: 3
Past 7 Days: 36
Past 30 Days: 159
All Time: 20,469
