Disassembling the Garmin eTrex Vista-H Outer Case
  1. Disassembling the Garmin eTrex Vista-H Outer Case, Removing Battery: step 1, image 1 of 1
    • Flip the device to the backside, and locate the metal tab at the center of the back cover.
  2. Disassembling the Garmin eTrex Vista-H Outer Case: step 2, image 1 of 1
    • Lift the metal tab up, and rotate it counterclockwise. This will unlock the back case cover.
  3. Disassembling the Garmin eTrex Vista-H Outer Case: step 3, image 1 of 2 Disassembling the Garmin eTrex Vista-H Outer Case: step 3, image 2 of 2
    • Lift the battery plate off to either insert or remove 2 AA batteries.
  4. Disassembling the Garmin eTrex Vista-H Outer Case, Disassembling the Garmin eTrex Vista-H Outer Case: step 4, image 1 of 2 Disassembling the Garmin eTrex Vista-H Outer Case, Disassembling the Garmin eTrex Vista-H Outer Case: step 4, image 2 of 2
    • With the wedge side of a spudger (or a small, flat head screwdriver), remove the black rubber case support from the device body.
  5. Disassembling the Garmin eTrex Vista-H Outer Case: step 5, image 1 of 3 Disassembling the Garmin eTrex Vista-H Outer Case: step 5, image 2 of 3 Disassembling the Garmin eTrex Vista-H Outer Case: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • With the pick side of a spudger (or tweezers), peel the sticky tape from the device.
  6. Disassembling the Garmin eTrex Vista-H Outer Case: step 6, image 1 of 1
    • Split the front and rear panels by inserting a small pointed tool (such as a pen point or a screwdriver tip SL1.5) in the 5 plastic tabs along the sides of the device.
    • Do not remove the back panels quickly. If too much force is applied, there is a wire connection that will break.
    • CAUTION! Be careful not to force the tabs inward. This will result in broken tabs.
  7. Disassembling the Garmin eTrex Vista-H Outer Case: step 7, image 1 of 2 Disassembling the Garmin eTrex Vista-H Outer Case: step 7, image 2 of 2
    • With tweezers (or your fingernails), carefully disconnect the wires between the PC input and the motherboard.
7 other people completed this guide.
Ryan Green
93 Reputation
1 Guide authored
Cal Poly, Team 21-30, Regan Fall 2010 Member of Cal Poly, Team 21-30, Regan Fall 2010
CPSU-REGAN-F10S21G30
3 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 16
All Time: 5,263
