Nintendo NES Advantage B Button Replacement
  1. Nintendo NES Advantage B Button Replacement, Back Panel: step 1, image 1 of 1
    • Remove the four sticky pads from the bottom of the device.
    • If the pads are stuck, use a spudger to remove them.
  2. Nintendo NES Advantage B Button Replacement: step 2, image 1 of 2 Nintendo NES Advantage B Button Replacement: step 2, image 2 of 2
    • Remove the six 8 mm screws from the bottom of the device with a Phillips #0 screwdriver.
    • Use your hands to pull the back panel away from the controller.
  3. Nintendo NES Advantage B Button Replacement, Circuit Board: step 3, image 1 of 2 Nintendo NES Advantage B Button Replacement, Circuit Board: step 3, image 2 of 2
    • Remove the three 14 mm screws from the gray cross with a Phillips #0 screwdriver.
    • Lift the gray component away from the device.
  4. Nintendo NES Advantage B Button Replacement: step 4, image 1 of 1
    • Lift up the black wire and move it to the side.
  5. Nintendo NES Advantage B Button Replacement: step 5, image 1 of 3 Nintendo NES Advantage B Button Replacement: step 5, image 2 of 3 Nintendo NES Advantage B Button Replacement: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the two silver knobs on the front of the device.
    • Unscrew the two silver nuts using a flathead screwdriver.
    • Remove each silver nut and silver washer using a pair of tweezers.
  6. Nintendo NES Advantage B Button Replacement: step 6, image 1 of 2 Nintendo NES Advantage B Button Replacement: step 6, image 2 of 2
    • Remove the remaining three 8 mm screws on the circuit board with a Phillips #0 screwdriver.
    • Remove the silver bracket from the top of the circuit board.
  7. Nintendo NES Advantage B Button Replacement: step 7, image 1 of 1
    • Remove the circuit board from the controller.
  8. Nintendo NES Advantage B Button Replacement, B Button: step 8, image 1 of 1
    • Remove the B button from the case (or the circuit board if it got stuck).
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 13
All Time: 301
