Nintendo Switch Dock Circuit Board Replacement
  1. Nintendo Switch Dock Circuit Board Replacement, Remove cables and wires: step 1, image 1 of 1
    • Unclip the back plate. It will fold back to expose the power wire and the HDMI cable.
  2. Nintendo Switch Dock Circuit Board Replacement, Prepare dock for disassembly: step 2, image 1 of 1
    • Remove the Switch from the dock
    • Orient the dock so that the adapter block faces up like shown
  3. Nintendo Switch Dock Circuit Board Replacement, Removing first set of screws: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Using a Tri-head 360x50 driver, unscrew the four screws shown (1, 2, 3, 4) and use mini-tweezers to remove the screws
    • Place the screws in a secure location where you will remember to get them later.
  4. Nintendo Switch Dock Circuit Board Replacement: step 4, image 1 of 1
    • Using Tri-head 360x50 driver, unscrew the next four screws shown (A, B, C, D) and use the mini-tweezers to remove the screws.
    • Place the screws in a secure location.
    Indicating the length of the screws for steps three and four would be very helpful, they are different lengths and I can't remember which ones go where and this guide is of no help with that.
    Heavens Rejected - Reply
    If anyone checks these comments I'm having the same issue. There are 4 of each and I don't know which step has the long screws and which has the short ones.
    Brian Holthouse -
  5. Nintendo Switch Dock Circuit Board Replacement, Removing the backing: step 5, image 1 of 2 Nintendo Switch Dock Circuit Board Replacement, Removing the backing: step 5, image 2 of 2
    • Carefully pull to remove the backing from the switch dock, exposing the circuit board.
  6. Nintendo Switch Dock Circuit Board Replacement, Remove the circuit board: step 6, image 1 of 1
    • Carefully unplug the red and black cable connecting the circuit board with the dock housing
    • This cable can be more easily removed with a pair of needle-nosed pliers. Clamp on to the plastic casing and gently pull to remove the cable
  7. Nintendo Switch Dock Circuit Board Replacement, Remove the film cable: step 7, image 1 of 1
    • Gently pull the film cable out of the circuit board. The cable should slide free when lightly pulled.
    alternatively, there is a hinged clip that holds it. Lift on the light grey bar to open and close the hinge holding the ribbon connector head in place.
    rockstartravesty - Reply
    This section should be updated to tell user that they need to lift up the latch on the ZIF socket. Lightly pulling it won't release the ribbon cable.
    Mike O'Sullivan - Reply
    • Unpack and inspect replacement circuit board - check for any damage or faults
  8. Nintendo Switch Dock Circuit Board Replacement, Reconnect film cable: step 9, image 1 of 2 Nintendo Switch Dock Circuit Board Replacement, Reconnect film cable: step 9, image 2 of 2
    • Carefully reconnect the film cable to the replacement circuit board. The cable should slide in when gentle pressure is applied.
    • Ensure the cable is oriented correctly before insertion to avoid damage.
  9. Nintendo Switch Dock Circuit Board Replacement, Reconnect red/black cable: step 10, image 1 of 2 Nintendo Switch Dock Circuit Board Replacement, Reconnect red/black cable: step 10, image 2 of 2
    • Make sure the cable is oriented correctly - you can check the port to make sure the holes will line up correctly
    • Align plug - end of cable to port and apply gentle pressure. The cable should slide back into place.
    • The circuit board should fit without obstruction.
  10. Nintendo Switch Dock Circuit Board Replacement, Reinsert circuit board: step 11, image 1 of 1
    • Gently apply pressure to the circuit board to ensure it seats into the housing.
  11. Nintendo Switch Dock Circuit Board Replacement, Put backing on: step 12, image 1 of 1
    • Place backing onto dock. All screw holes should line up.
    • Apply gentle pressure. (You should feel a slight "give" as it seats properly)
  12. Nintendo Switch Dock Circuit Board Replacement, Reinsert screws Part 1: step 13, image 1 of 1
    • Use Tri-Head driver to reinsert screws (A, B, C, D)
    These four are the longer Tri-wing 00 screws.
  13. Nintendo Switch Dock Circuit Board Replacement, Reinsert screws Part 2: step 14, image 1 of 1
    • Use Tri-head driver to reinsert screws (1, 2, 3, 4)
    This one is where the four stubby (SHORT) tri-wing screws go.
  14. Nintendo Switch Dock Circuit Board Replacement, Reinsert cables: step 15, image 1 of 1
    • Plug HDMI and power cable into switch dock.
  15. Nintendo Switch Dock Circuit Board Replacement, Connect with an HDMI device: step 16, image 1 of 1
    • Plug HDMI cable into a device with an HDMI port (TV, monitor, computer, etc.) (NOTE: need adapter for PC for video and audio connection)
  16. Nintendo Switch Dock Circuit Board Replacement, Using the dock Part 1: step 17, image 1 of 1
    • Insert Nintendo Switch into dock and turn it on.
    • The dock should charge your switch. If it doesn't, check the power supply/power cable
    • When correctly seated in the dock, the Switch screen will remain black
    • Use Switch normally to test audio and video output
    • If Switch works normally but the dock doesn't, check to make sure the following are true:
    • Both cables are plugged in correctly
    • Both cables are not obstructed or damaged
    • Circuit board is not damaged
    • Circuit board seats correctly into housing
All electrical equipment should be stored safely out of the way of hazards. After replacement, the Switch Dock should function properly.
11 other people completed this guide.
[deleted]
585 Reputation
1 Guide authored
5 Comments
At https://www.hollywood-docks.com, we specialize in new dock installations, existing dock repairs and updates, seawall installations and repairs, deck and patio construction, and much more. We pride ourselves on providing high-quality craftsmanship and exceptional customer service.
Paul Walker - Reply
Wrong kind of dock, bro.
modtang -
Conecta el cable HDMI a un dispositivo con un puerto HDMI
Vlad Luk - Reply
Enchufa el HDMI y el cable de alimentaciĆ³n en la base de la Switch.
Vlad Luk -
had a bad surge and now dock isn't working (but the power cord will charge the switch directly)
how do I tell if it is the circuit board or the USBC board that is bad?
Jeff - Reply
Past 24 Hours: 37
Past 7 Days: 193
Past 30 Days: 787
All Time: 32,102
