Nintendo Switch Fan Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Nintendo Switch Fan Replacement, Fan: step 1, image 1 of 1
    • Remove the two 4.8mm JIS #000 screws from the fan.
  2. Nintendo Switch Fan Replacement: step 2, image 1 of 2 Nintendo Switch Fan Replacement: step 2, image 2 of 2
    • Use a spudger to flip up the small gray locking flap on the fan ZIF connector.
  3. Nintendo Switch Fan Replacement: step 3, image 1 of 3 Nintendo Switch Fan Replacement: step 3, image 2 of 3 Nintendo Switch Fan Replacement: step 3, image 3 of 3
    • Lift the left side of the fan out of its recess and rotate it 15 degrees towards you.
    • Pull the fan out and away from you to unhook it from the rubber grommet.
Blake Klein
73,862 Reputation
50 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 198
