Nintendo Switch OLED Model Dock Motherboard Replacement
  1. Nintendo Switch OLED Model Dock Motherboard Replacement, Remove the rear cover: step 1, image 1 of 3 Nintendo Switch OLED Model Dock Motherboard Replacement, Remove the rear cover: step 1, image 2 of 3 Nintendo Switch OLED Model Dock Motherboard Replacement, Remove the rear cover: step 1, image 3 of 3
    • Use your fingers to pull the rear cover away from the frame and release its plastic clips.
    • Remove the rear cover.
  2. Nintendo Switch OLED Model Dock Motherboard Replacement, Unfasten the baseplate: step 2, image 1 of 2 Nintendo Switch OLED Model Dock Motherboard Replacement, Unfasten the baseplate: step 2, image 2 of 2
    • Use a Y0 screwdriver to unfasten the 7.5 mm-long screw securing the baseplate to the frame.
  3. Nintendo Switch OLED Model Dock Motherboard Replacement, Remove the screw cover: step 3, image 1 of 3 Nintendo Switch OLED Model Dock Motherboard Replacement, Remove the screw cover: step 3, image 2 of 3 Nintendo Switch OLED Model Dock Motherboard Replacement, Remove the screw cover: step 3, image 3 of 3
    • Insert an opening tool between the frame and the plastic screw cover at the bottom-left corner.
    • Pry up with the opening tool to separate the screw cover from the frame.
    • Remove the screw cover.
  4. Nintendo Switch OLED Model Dock Motherboard Replacement, Unfasten the midframe: step 4, image 1 of 2 Nintendo Switch OLED Model Dock Motherboard Replacement, Unfasten the midframe: step 4, image 2 of 2
    • Use a Y0 screwdriver to remove the seven screws securing the midframe to the frame:
    • Four 3.9 mm screws
    • Three 7.5 mm screws
    • One 3.9 mm screw
  5. Nintendo Switch OLED Model Dock Motherboard Replacement, Remove the midframe: step 5, image 1 of 3 Nintendo Switch OLED Model Dock Motherboard Replacement, Remove the midframe: step 5, image 2 of 3 Nintendo Switch OLED Model Dock Motherboard Replacement, Remove the midframe: step 5, image 3 of 3
    • Use your fingers to remove the midframe from the frame.
  6. Nintendo Switch OLED Model Dock Motherboard Replacement, Remove the baseplate: step 6, image 1 of 3 Nintendo Switch OLED Model Dock Motherboard Replacement, Remove the baseplate: step 6, image 2 of 3 Nintendo Switch OLED Model Dock Motherboard Replacement, Remove the baseplate: step 6, image 3 of 3
    • Use your fingers to pull the baseplate away from the frame and release it from its plastic clips.
    • Remove the baseplate.
  7. Nintendo Switch OLED Model Dock Motherboard Replacement, Disconnect the motherboard: step 7, image 1 of 2 Nintendo Switch OLED Model Dock Motherboard Replacement, Disconnect the motherboard: step 7, image 2 of 2
    • Use the flat end of a spudger to lift up the small locking flap on the motherboard cable's ZIF connector.
  8. Nintendo Switch OLED Model Dock Motherboard Replacement: step 8, image 1 of 2 Nintendo Switch OLED Model Dock Motherboard Replacement: step 8, image 2 of 2
    Tool used on this step:
    Buy
    • Use a pair of tweezers to slide the cable out of its connector.
  9. Nintendo Switch OLED Model Dock Motherboard Replacement, Remove the motherboard: step 9, image 1 of 3 Nintendo Switch OLED Model Dock Motherboard Replacement, Remove the motherboard: step 9, image 2 of 3 Nintendo Switch OLED Model Dock Motherboard Replacement, Remove the motherboard: step 9, image 3 of 3
    • Use your finger to pull back on the plastic release tabs holding the motherboard in place.
    • Pull the motherboard up and away from the frame to remove it.
    • Don't fully remove the motherboard yet, as it's still connected to the frame via a JST cable.
    • Rest the motherboard by the frame before moving on to the next step.
  10. Nintendo Switch OLED Model Dock Motherboard Replacement, Disconnect the LED: step 10, image 1 of 2 Nintendo Switch OLED Model Dock Motherboard Replacement, Disconnect the LED: step 10, image 2 of 2
    • Use blunt tweezers, or your fingers, to pull the LED's JST connector out of its socket.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch OLED Answers community for help.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Alex Diaz-Kokaisl
161,945 Reputation
769 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,410 Guides authored
2 Comments
Bonjour, bravo pour le tuto.
je suis à la recherche de la même carte mère.
avez-vous les références et surtout, où la trouver ?
Merci beaucoup.
daniel.lamand@orange.fr - Reply
Il y a cette pièce d'Aliexpress. Ce sera la meilleure offre : https://www.aliexpress.us/item/325680569...
Alex Diaz-Kokaisl -
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 92
All Time: 2,727
