Nintendo WaveBird Wireless Controller Front Panel Replacement
  1. Nintendo WaveBird Wireless Controller Front Panel Replacement, Batteries: step 1, image 1 of 2 Nintendo WaveBird Wireless Controller Front Panel Replacement, Batteries: step 1, image 2 of 2
    • Pull down on the battery cover release lever and pull back to remove the cover.
  2. Nintendo WaveBird Wireless Controller Front Panel Replacement: step 2, image 1 of 1
    • Remove both batteries from the device.
  3. Nintendo WaveBird Wireless Controller Front Panel Replacement, Front Panel: step 3, image 1 of 2 Nintendo WaveBird Wireless Controller Front Panel Replacement, Front Panel: step 3, image 2 of 2
    • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
    • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
  4. Nintendo WaveBird Wireless Controller Front Panel Replacement: step 4, image 1 of 2 Nintendo WaveBird Wireless Controller Front Panel Replacement: step 4, image 2 of 2
    • Carefully turn over the controller and place it on a flat surface.
    • Slowly separate the top panel from the bottom panel.
    • The buttons are loose and may fall off the motherboard.
    • Once separated, set aside the top panel.
    • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
3 other people completed this guide.
JT Gryder
114 Reputation
1 Guide authored
Cal Poly, Team 10-40, Amido Spring 2013 Member of Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
4 Members
37 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 5
Past 30 Days: 14
All Time: 1,771
