Nintendo WaveBird Wireless Controller Joystick Replacement
  1. Nintendo WaveBird Wireless Controller Joystick Replacement, Batteries: step 1, image 1 of 2 Nintendo WaveBird Wireless Controller Joystick Replacement, Batteries: step 1, image 2 of 2
    • Pull down on the battery cover release lever and pull back to remove the cover.
  2. Nintendo WaveBird Wireless Controller Joystick Replacement: step 2, image 1 of 1
    • Remove both batteries from the device.
  3. Nintendo WaveBird Wireless Controller Joystick Replacement, Front Panel: step 3, image 1 of 2 Nintendo WaveBird Wireless Controller Joystick Replacement, Front Panel: step 3, image 2 of 2
    • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
    • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
  4. Nintendo WaveBird Wireless Controller Joystick Replacement: step 4, image 1 of 2 Nintendo WaveBird Wireless Controller Joystick Replacement: step 4, image 2 of 2
    • Carefully turn over the controller and place it on a flat surface.
    • Slowly separate the top panel from the bottom panel.
    • The buttons are loose and may fall off the motherboard.
    • Once separated, set aside the top panel.
    • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
  5. Nintendo WaveBird Wireless Controller Joystick Replacement, Buttons: step 5, image 1 of 3 Nintendo WaveBird Wireless Controller Joystick Replacement, Buttons: step 5, image 2 of 3 Nintendo WaveBird Wireless Controller Joystick Replacement, Buttons: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to remove the buttons.
    • It may be easier to remove the A button off of the pad by lifting it with your fingers.
    • During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
  6. Nintendo WaveBird Wireless Controller Joystick Replacement, Joystick: step 6, image 1 of 2 Nintendo WaveBird Wireless Controller Joystick Replacement, Joystick: step 6, image 2 of 2
    • Grab the base of the grey joystick cover with one hand and firmly hold down the rest of the controller with the other hand.
    • Pull off the grey joystick cover.
    • During reassembly, make sure the slots inside the joystick cover line up with the motherboard so it can fit back together.
8 other people completed this guide.
Garrett Leung
979 Reputation
8 Guides authored
Cal Poly, Team 10-40, Amido Spring 2013 Member of Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
4 Members
37 Guides authored
1 Guide Comment
Question. My wavebird joystick wobbles a lot and gets stuck in directions I’m not inputting. Will replacing the top of the stick fix this? Or would I have to solder a new analog stick to the board?
Golgamang - Reply
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 64
All Time: 10,842
